I received a yard cart with a old 5hp B&S engine that I decided to fix up for my son. I ended up junking the B&S engine due to multiple issues that made replacement easier and cheaper. I bought a Predator 212 6.5HP hemi head motor from harbor freight.... I replaced the clutch due to the old one was well stuck onto the old motor. I got a Masters Of Motion model 12884H which is 10 teeth from tractor supply and yes it is marked for go karts....
Now onto my issue, I had a problem getting the throttle cable hooked up when I started on this in the Spring with installing the new engine and clutch. I ended up having to redo the throttle assembly which required ordering parts. So now I finally got back around to this project now in September to try to get it going for my lil guy for now Fall riding weather. Once it was all together the engine fired up first pull and ran well. After minutes of idling... I decided to try to see how the throttle would work.... It worked fine except the kart did not go anywhere! The clutch smoked and acted like it had no torque to get up and go. The sprocket has 58 or 60 teeth when I counted... so 6:1 ratio...
My father in law helped with installing the clutch... I fear the key was thrown away that came with the engine... but I think this clutch had one built in? Is there anything beyond pulling the clutch off to check the installation I should do first? What do you think is wrong??
