Clutch Issue
Chiggins
I received a yard cart with a old 5hp B&S engine that I decided to fix up for my son. I ended up junking the B&S engine due to multiple issues that made replacement easier and cheaper. I bought a Predator 212 6.5HP hemi head motor from harbor freight.... I replaced the clutch due to the old one was well stuck onto the old motor. I got a Masters Of Motion model 12884H which is 10 teeth from tractor supply and yes it is marked for go karts....
Now onto my issue, I had a problem getting the throttle cable hooked up when I started on this in the Spring with installing the new engine and clutch. I ended up having to redo the throttle assembly which required ordering parts. So now I finally got back around to this project now in September to try to get it going for my lil guy for now Fall riding weather. Once it was all together the engine fired up first pull and ran well. After minutes of idling... I decided to try to see how the throttle would work.... It worked fine except the kart did not go anywhere! The clutch smoked and acted like it had no torque to get up and go. The sprocket has 58 or 60 teeth when I counted... so 6:1 ratio...
My father in law helped with installing the clutch... I fear the key was thrown away that came with the engine... but I think this clutch had one built in? Is there anything beyond pulling the clutch off to check the installation I should do first? What do you think is wrong??
KartFab
Dallas, TX
What size tires does it have? Was the kart trying to go uphill?
You can literally cook the clutch by frequent start/stops and/or big tires and/or driving up steep inclines and/or slow driving and/or a heavy kart.
Pull the clutch off and check the key first, but a smoking clutch may mean you have other issues.
Chiggins
What other issues could it be?. It was in my front yard while not completely flat it should of moved. But this thing was pretty much dead in the water with no power. Like the clutch wasnt engaging... I know have it narrowed down to power transfer from the engine to the wheels... Engine is brand new and running great...
Chiggins
Thanks for the article... its a regular little yard kart little turf tire but I will measure very soon and post.
And for the sprocket count questions... Its a 10 tooth Masters of Motion clutch (Tractor supply) tied to a 60 tooth sprocket on the drive tire. It is NOT a live axle. So its 1:6 gear ratio.
---------- Post added at 09:32 AM ---------- Previous post was at 09:02 AM ----------
To be honest I am very confused about what is going on... I had this cart with its old clutch (10 teeth) and 5HP B&S Engine... While the engine had bad carb issues, it had power to go... Now new engine little more HP and new (but from my understanding pretty much same clutch), it won't move....
Poboy kartman
Senior Moments Member
White Settlement Texas
Ok....now if it indeed did not have a key...the clutch would spin on the shaft....meaning the engine would rev....but the clutch would not attain enough rpms to engage causing it to slip and smoke.....
Make sense???? Check that first....
Chiggins
While at work today, I found out the clutch has a "Built in" key when looking up the clutch... That is probably why I remember him getting rid of the existing key on the engine... I do know we didn't do anything extra except putting the clutch on the crank shaft and put the hardware and bolt into the end of the crank. Maybe I missed a step? Anyone every use one of these tractor supply clutches? Are there any screws that you should tighten down?
Poboy, I will pull the clutch if you still think I need to knowing the clutch has a built in key. Should I? I really appreciate the replies. Due to being a contractor I have very limited time till winter but my son is so excited I am putting the very limited amount of time I do have into this thing.
Chiggins
I got the kart moving now.... A big abjustment on the throttle and put it on the road its running strong... Just need more power I guess to engage... But up a grass hill and it smoked... So should I go up to a 70 sprocket? Would I lose alot of speed?? Would it make the kart alot better for hill from the 60 tooth one it already has?
OP- I think KartFab's post needs another look at....
His first question is... What is the tire size......
Just sayin...
Gearing lower will definitely cause your clutch to smoke less. Whether it will be low enough for you.....you will have to find that out by trial and error.
Tyre size?
