Clutch help
Avery
Hi all!! I just picked up a cart, I'm told it's a yerf dog. Engine is of it. It's a chain drive set up ( no belt). It has a Hillard clutch. My issue is there was some sort of sleeve that went on it that's not there. So I was looking at the clutches and I found Hillard. My question is must I use Hillard? It's a 6.5 predator engine, cart is a 1 seater. I'll attach pictures of old clutch and what I'd like to use.
Avery
Ond why do you prefer max torque clutch?
---------- Post added at 08:23 AM ---------- Previous post was at 08:18 AM ----------
Also how do I know what chain (pitch ) I have?
Off hand... That's a #41 chain clutch... Like the ad says...
Had it have 12...it'll be a #35 chain, as those are the most common...
Alot like the Hilliard clutches as they have C-shaped springs,
, and with the verity out there one can easily customize the engagement point, whereas the other type typically out there has one long garter spring with fixed engagement point.
anickode
S.E. Michigan
Hillard and max-torque are good brands.
I prefer max-torque.
No-brand Chinese ones... I really can't speak for.
