clutch extremely hot problem
NotSoMasterMind
South lyon michigan
NO....the main point of why jackshaft is being repeated... It allows compound gearing.....
and other options....
My bike has a large rear tire.. A spare car tire. This has a large 24" OD. Now aside of a few engineering details(the right side drive), I needed the jackshaft to modify the gearing from just having a chain to the clutch to the rear tire.
In you kart. you have a tall rear tire, and a burning clutch. adding a jackshaft to modify the gearing set to accommodate those elements, to reduce strain on the clutch.
Off hand..... some numbers I just through out there...
14-24-14-60 =7.347:1...... thats a start...
Heres the ratio calc...
http://www.affordablegokarts.com/GearCalc.php
We also need some pic on what were dealing with?
here are some pics
Poboy kartman
Senior Moments Member
White Settlement Texas
they are 17 inch tires.... would it really be that hard to turn it, causing it to get hot? or can i get something to cool it down?
Just drive it underwater....REALLY? Dude! This is not that complicated..... just listen up...and do what we say....
You want to put a radiator on a clutch...instead of properly gearing your kart....you want to add a chain tensioner...instead of simply slotting your engine plate..(or replacing it with the proper one off the net.)
Jeesh....
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Keeping it cool is NOT the issue, Heat is the result of the clutch Slipping. The slipping is the problem that will destroy the clutch. The heat is just the product of it slipping..
All you need to do is buy a 10 tooth clutch. 20 bucks on ebay.
Although your tires are still oversized for the 6:1 ratio of a 10 tooth. You will be alot better off, and 20 bucks make it worth a try.
Kelly Wood
The Mad Kartist
Salt Lake City Utard
See NotSoMasterMind?
You're not listening. Every single person here that has joined in are trying to help you and know what they're talking about. Sure, some may rub ya the wrong way but that's just life. Some may even hate me too, but you can't please everyone. This is all valid information.
Go back and re-read this whole thread and see what we're telling you.
NotSoMasterMind
South lyon michigan
Jeesh....
at most i can move my engine 1/2 inches, the engine hardly fits on the mounting plate
---------- Post added at 08:26 PM ---------- Previous post was at 08:24 PM ----------
and i have a 1inch bore, $60 for the cheapest clutch i can find.
Poboy kartman
Right......so....you are going to destroy a high dollar 1" bore clutch because you simply cannot seem to grasp that you MUST change your gearing.
Or that the purpose of a jackshaft is not to change where the sprockets are..but to allow a smaller axle sprocket to achieve a higher gearing..(something you desperately need).
Now.....you can probably run a 90 something tooth sprocket...without ground clearance issues if it mounts to the wheel....and this is only going to set you back $20 or $30....sooooo.....maybe you don't need a jackshaft, but......you DEFINITELY need higher gearing.
And....again...I don't give a hoot how tight it is (in your mind) to "fit" this engine. Simply slotting your engine plate and choosing the right amount and kind of links is the cheapest, easiest. way to solve your loose chain issue.....
We can't help you if you don't listen.
NotSoMasterMind
South lyon michigan
thanks, the best anwser i got all day... thanks for the info, i might just go with this :thumbsup:
---------- Post added at 09:35 PM ---------- Previous post was at 09:15 PM ----------
you can get somthin like this and not have to weld anything and be able to adjust your chain. http://www.minichopperssocal.com/JACKSHAFT-SYSTEM.html
thanks so much!!!
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Maybe you can find a smaller sprocket for your clutch. again maybe 20 bucks
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Here is a selection of sprockets for your clutch....
like Chancer said... about ~$20....
http://www.bmikarts.com/Replacement-Parts_c_219.html
I just looked at that link the problem is Smallest seems to be 15 tooth. and You already have 14. So looks like Jackshaft or Axle sprocket, is the way to go. I did not realize with a 1" shaft it is probably not possible to get a 11 or 12 tooth clutch sprocket.:thumbsup:
