Clutch/Engine Help
THill16
I need some help with issues with a replacement engine for an ongoing go-kart project.
Just purchased a Honda 5 hp off of craigslist ($20 and runs great) it was apparently from a power washer.
The problems are that the shaft size is 7/8” and extremely short (less than 2”) and the end hole is not threaded for a bolt to hold a clutch on.
How should I approach fitting a centrifugal clutch to it? (Preferably in the most cost effective way haha)
I have searched the net for about 3 hours trying to find some answers but have come up with little.
Any advice would be great!
(The only knowledge I have on fitting a clutch on is from the engine previously on the kart, which had a 3/4” shaft with a pretty standard looking clutch mated)
Update: I'm now leaning on replacing the crankshaft, preferably with a 3/4".. Need to know some information about the different 5HP models of Hondas and if the parts are interchangeable with the one I have.
Shaft
Only serial looking # I could find on it is '2HNXS 1611AK'
Bluethunder3320
ouchh. i dont know if its possible to get a 7/8 clutch (if they exist?) and tap the hole (lol) in the end of your shaft for a bolt.
THill16
I have seen some 7/8" and 1" clutches on the web.. so they do exist but they are pricey .. For a 1" clutch to work I would have to use a bushing to get it fitting correctly..
But my main problem is that the shaft is so short that I am hesitant to even begin to look at ordering a clutch until I know one will fit.
THill16
I need to know a little more about honda engines..
Are the parts pretty universal? I'm having trouble finding any matching engines listed under the serial number on mine. If I find a crankshaft for a different honda 5.0 hp model like the GC160 or GXV140 will it fit?
+ I have found some 3/4" crankshafts for the GC160 model. You think it would fit my vaguely identified honda 5.0 hp model?
Specifically looking at this part number : 13310-ZL8-600 which is a 3/4" shaft for the gc160
