betoeclipse1
thats not the right crank. how did you decide what part number to order? if its a real honda engine, it will have honda on the case itself, somewhere. if not, its a clone, and which brand would be a guess. the new crank you buy/bought MUST look exactly the same as your original one, except that it would have the standard shaft end ,versus the "use specific" crank end that you have. that engine was designed to turn like small cement mixers and such,hence the 2:1 reduction box.
if you bought that crank at the advise of a salesman at a kart supply business, then he was a much clueless as a newb.......
Ok i will be returning this one and any idea where i can order one?
