clutch differences?
betoeclipse1
cartersville georgia
The only difference i see is on the set screws . Anyone have an idea off whats the difference i have one with the set screws on the end but wont engage...
the other way around, weak springs mean very early engagement.
But shoes can lock up from dirt or rust or debris...
Also, not every clutch is meant to run on every engine.
You can't run a 2stroke clutch on your 4stroke engine for example;
mainly because racing 2 stroke clutches engage at around 4000-4500 rpm
[yes settable, but that's not uncommon],
and the common 4stroke engine governs at 3600 rpm so way below needed rpms.
you could also have forgotten (or sheared) your key, so the clutch engages properly, but the missing key is allowing the crank to run inside the clutch which will then disengage again...
So, post pics, specs if you have them and we'll find the cause
and will likely be able to point you in the right direction.
difference, the left one is a maxtorque (or clone) SS, the right one a Noram (or clone) I guess.
different shoe design, different springs, bells etc...
(set screws are on the backside of the maxtorque in case you need them)
but if the right one is what I think it is,
there will be no noteworthy difference on a std fun kart.
Both will engage at about the same rpm (1800-2000) both will withstand only minor abuse before frying up and both will be in about the same price range;
there you have it...
it looks like you have a 2:1 reduction box installed;
one that doesn't include a clutch itself..
is that correct?
If so, that clutch will NOT engage, since the fastest the engine turns is 3600 rpm, and the fastest the clutch will turn is 1800 rpm..
just when the clutch is barely trying to engage (full lock at 2000 rpm, a speed it can never reach)
loose that gear reduction box, and adjust your gear ratio accordingly.
betoeclipse1
No i dont have any gear reduction its a 8 honda hp engine.....1" shaft goin on a 20 sprocket with a 10 shaft with a 45 axle spriket
---------- Post added at 10:51 PM ---------- Previous post was at 10:13 PM ----------
How do i loose the gear reduction box please help
---------- Post added at 11:12 PM ---------- Previous post was at 10:51 PM ----------
It looks like i do have a 6 :1gear reduction engine....can i use it or not....
Alex is talking about this reduction box, the one i have circled. You can remove it from the engine. It should just be a bolt on affair. I can see the bolts in the pic
betoeclipse1
Not as easy as unbolting . Just ordered a new crankshaft and front cover.the old crankshaft is to short and the cover will not work. Thanks every one that help figure it out.
betoeclipse1
Installed the new crankshaft and its has alot of play . Could it be it does have the engine balancer and also it didnt want to crank i may nee to adjust the valves any suggestions ?
rocketkart
florida
look like you got a crank for a honda 390 engine you need one for a gx260. make sure thay are the some other than the outside shaft and make sure you line up the timing dot on the gears.
machinist@large
West Michigan, 49331
:idea2: Do you have any precision measuring tool's? Even the cheapest $9.99 on sale set of digital calipers from HF, used correctly, is way better than none. Without a way to confirm what you started with to where you are now, its really difficult for the rest of us to help with the diagnosis.....
betoeclipse1
Yes i aligned the dots correctly and i ordered it for a gx240 but i have a gear reduction an it has a engine balancer and the one i receive does not have the gear for it . It almost cranked yesterday but in doing so the pull cord layer pulled apart. Im about sick of messing with it really thinking of goin with a HF engine .
---------- Post added at 08:02 PM ---------- Previous post was at 08:00 PM ----------
Yes i have one what im i looking for ? Once i get new pull cord in i will adjust the valves and if that doesnt work i will start from scratch...
machinist@large
..........Yes i have one what im i looking for ? Once i get new pull cord in i will adjust the valves and if that doesnt work i will start from scratch...
Any difference between the original crankshaft and the new one. In this age of clone's, you need to be sure you have the correct parts. As for the pull cord, almost any auto parts store will have that on the shelf, complete with a much better handle.
firemanjim
Just kartin' around....
Houston Texas
thats not the right crank. how did you decide what part number to order? if its a real honda engine, it will have honda on the case itself, somewhere. if not, its a clone, and which brand would be a guess. the new crank you buy/bought MUST look exactly the same as your original one, except that it would have the standard shaft end ,versus the "use specific" crank end that you have. that engine was designed to turn like small cement mixers and such,hence the 2:1 reduction box.
if you bought that crank at the advise of a salesman at a kart supply business, then he was a much clueless as a newb.......
