Hi guys newbie here to the carting world. OK i am trying to get my sons cart running right but am running into some problems. The cart is a 5.5 HP honda engine with a centrifugal clutch. The original carb on the cart would run better if the choke was kept half closed leading me to believe there was a fuel restriction somewhere so i removed the carb and tried to clean it but the jets would not come out. After purchasing a new one i installed it and it kind of still does the same thing. Fuel restriction to the carb isnt an issue. It seems like there is a heck of a bog when you hit the gas even with the new carb. Another problem is that when my son sits on it and mashes the throttle it wont hardly move at all.Tore the clutch apart and cleaned it and still doesnt work. If i raise the rear tires off the ground or put the front end against something it will spin the tires but any weight on it at all will almost stop it completely. Could the centrifugal clutch be history? I havent counted the number of teeth yet on the sprockets but i will do so tomorrow as its 10 degrees here without the wind chill...lol. The guy who owned the cart before me raced it and was also wondering if the gearing was designed for speed instead of torque? The axle sprocket looks real big so wiouldnt that give me the torque to at least pull out? Thanks for any help anyone can provide on this.
