Clone stock air filter removal
jandj
Williamsburg, Va
To take the plastic "base" off (after removing the outer housing and the filter itself) there's two Phillips head screws and a bolt.
Attempting to remove the bolt -A 6 point 10mm socket wants to slip, 9mm's too small.
I have a set of those Snap-On "splined" sockets, but the 10mm one doesn't fit any tighter than the 6-point does..
The stock box can stay on for now, but eventually it's got to go.
I don't want to round off the bolt, any suggestions?
When I took mine apart, I don't remember hitting a difficulty there. Sorry I can't help, other than to suggest the factory must've gotten some really cheap hardware. Have you tried a 3/8" socket, which IIRC is a wee bit smaller than 10mm?
jandj
Williamsburg, Va
I think toystory's on the right track!
In this case knowing the bolt size doesn't tell me much more than I already knew.
Bolt head is 9.78mm - too big for a 9, too small for a 10.
I do have (have no idea where I got it) a 9.5mm socket, but even it wants to slip - how tight did they think that bolt needed to be, for Pete's sake?
In American, the bolt head is .3850 inch.
3/8 is .3750 (might be able to "tap" it on, it doesn't want to go as is. I'm guessin' the metal isn't that tough)
It's gonna come off eventually, just don't want to make it any more of a pain in the *** than it already is.
redsox985
PA
Is this the bolt under the stock air filter? Mine came off with a 10mm but no SAE socket would fit.
Blazkowiez
Kart Aficionado
Houston, Texas
On every clone I've taken apart you need a 10mm, however the problem lies in having one thin walled enough to drop onto the bolt.
jandj
Williamsburg, Va
It put up a good fight, but I finally won!
I found an old set of feeler gauges, took one of the really thin ones, cut a "shim", put it in the 10 mm. socket and lightly tapped it down on the bolt head until it bottomed out against the shoulder.
It was still tighter than I expected, but it didn't slip or damage the bolt head.
Ta Daa!
r_chez_08
Should be in the shop...
Cornwall, UK
Nice! If it was me I would have probably stripped it, cursed and had to cut it off, or take the stud out of the engine lol.
Rob
jandj
Williamsburg, Va
Before I retired, I spent almost 30 years as a mechanic for the state DOT, which meant a lot of "road calls".
Sometimes you didn't have everything you needed on the service truck and had to figure out a way to at least get whatever piece of equipment it was back to the shop.
I went back to that thought process and,as Gru ("Despicable Me") says - "Lightbulb!"
Bluethunder, that's just what I did - went to the "bolt bin" and got a good 'un!
jandj
Williamsburg, Va
Whatever it takes, man!
You'd be surprised how long duct tape wrapped around a leaking gas tank will hold!
It don't hold up to much hydraulic pressure, though...
What a PITA! Must've been a particularly crappy batch of hardware the factory received.
EDIT- Wait- you killed a feeler gauge! Ack!
Maybe I didn't notice that problem, because when I tore that stuff off mine, I was using 1/4" drive tools? (ie thin) Still, the 10mm socket did not feel sloppy on the fastener.
