Clone modding question
Stephen115
I'm getting ready to build my friends 6.5hp honda clone. He doesn't have much to spend but I'm making it work.
Cam .256" lift
flat top piston
air filter/adapter
18lb valve springs
My question is, which one does he really need, the flat top piston or the billet rod? they are both the same price. since he's on a budget at this time its one or the other. I've heard the pistons are stronger than the rods?
I'll be port and polishing the heads.
thank you
SJ
Jcotz
...wasn't there
NY
If the governor is out, I would say the billet rod is more necessary. The 18lb valve springs will allow you to rev higher without valve flutter, so it has a higher chance of catastrophic rod failure. If not, then the rod is really not that necessary.
Stephen115
if I leave the governor and all that, could I run the piston? but then again id need to rev higher, so id need the rod?
Jcotz
...wasn't there
NY
To be honest, I'm not really sure if a flat top piston is "drop in and go", someone else might be able to tell you. However, I do know that a removed governor coupled with heavier valve springs and stock rod, could end badly.
:iagree: get the rod first, piston later when he has more money. Ideally, you want to do them both at the same time; see if he can hold off for a while & save more money. If you have to tear an engine down, you only want to do it once: every time you open it up it costs you money (gaskets, time, oil, etc)
Stephen115
true, thank you
