Stephen115
- Messages
- 382
- Reaction score
- 1
I'm getting ready to build my friends 6.5hp honda clone. He doesn't have much to spend but I'm making it work.
Cam .256" lift
flat top piston
air filter/adapter
18lb valve springs
My question is, which one does he really need, the flat top piston or the billet rod? they are both the same price. since he's on a budget at this time its one or the other. I've heard the pistons are stronger than the rods?
I'll be port and polishing the heads.
thank you
SJ
Cam .256" lift
flat top piston
air filter/adapter
18lb valve springs
thank you
SJ
get the rod first, piston later when he has more money. Ideally, you want to do them both at the same time; see if he can hold off for a while & save more money. If you have to tear an engine down, you only want to do it once: every time you open it up it costs you money (gaskets, time, oil, etc)
