Well if I'm going to have a battery and have less than impressive charging capabilities, I should probably have an idea what my voltage is.
Battery was 13.67V out of the box.
Have it hooked up to a 400mA float charger from HF.
Charger Voltage is 14.4 Volts.
Battery is now 13.83V after ~30-45 minutes on the charger.
https://www.aliexpress.com/item/New...8Od8-HYoPEBFx8wqHdcaAigAEALw_wcB&gclsrc=aw.ds
New Arrival Hot Sale Waterproof 0.28 DC 3.5-30V Mini LED Digital Voltmeter Volt voltage Meter F 12V Car Moto 10%Off
Since I have extra switches now, I'll put the voltmeter on the ON-OFF rocker switch I was going to use for the light.
Anybody know what the wattage is on a normal Baja style headlamp???
I assume I can replace it with a lower wattage LED light.
One of these would draw 1.5 amps.
https://www.amazon.com/Auxbeam-1800lm-Driving-Lights-Trucks/dp/B00T62RK1U
1.5 amp for light, 1 amp for pump.
The 5 hr 3.06 Amp discharge capacity of a similar battery is 15.3 Ah.
Three hours of riding might use 7.5 Ah. With no charging system (and using the pull starter) I should be able to use the battery to run the lights and pump for 3 hours without discharging more than 50%.
The charging system is a 3 amp charging system. Leaves 0.5 amps to charge the 18Ah (20 hour, 0.9 amp discharge rating) battery.
0.5 charging amps / 18 =
~0.025C (20hr)
or
0.5 charging amps / 15.3 =
~0.033C (5hr)
Charging system should run light and pump and also slow charge the battery to recover from using the electric start.
These are specs for a UB12180
https://www.sunwize.com/wp-content/uploads/2018/02/Data_Sheet-1-D5745.pdf
---------- Post added at 11:36 AM ---------- Previous post was at 10:50 AM ----------
I would rather have a push button versus a toggle switch. But you are correct that It is momentary.
Also remember that this switch will not have idiot proofing. If the engine is running and you hit that button again, the starter will engage the flywheel.
When I learned to drive, cars were not idiot proof either.
I haven't tried to start my current car while running on purpose, but I assume it has idiot proofing???
I don't think I will have an issue hearing if this engine is running or not.
If you can't hear yourself think, don't press the start button. LOL
EDIT:
The bulb on a stock baja appears to be 35Watts.
https://www.monsterscooterparts.com...zqgqZqUcrERxFBARQDpIZ8BQ3HidJ-RgaAkt4EALw_wcB
