Total Newb to Relays and suck at electronics.
Looking for a way to wire a 12V 1 amp fuel pump so that it turns on and off with the ignition key. That seems easy. A 12V SPST 4 Prong Normally Open Relay should do that.
There should be a wire from the ignition key box thing to power the relay right? What wire do I use?
Ideally, I'd also like the pump to turn off if I kill the engine via remote wired kill switch on handle bars or something. Is there an easy way to accomplish those simple needs?
