Clark Cyclopes 440 revival
Rusty wrench
Hey everyone .. picked up this Clark Cyclone 440 Frankenstein to start a rebuild with my young boys. Needs work but the plan is prob to make a new pan, strip the frame, cut off random pieces added on, and fix the front geometry. If anyone has the front axle dimensions and caster/camber angles that would be amazing. I’m missing a brake pedal as of now if someone has a set laying around. I’ll post updates as we move along.
Your orignal left pedal is missing/does not match the right. I think these are the closest to the original Clark branded pedals. They might even say “Clark” on them:
Try sandblasting the frame first, or wire wheeling it. It might be okay because it looks like surface rust, mostly.
Rusty wrench
Sandblasting and powder coating will happen for sure once the frame is straightened back up
Keep an eye on that weld where the front axle meets the frame. The slight rearward bend make a torsion force instead of just a vertical force on that joint.
Both of my dingos have suffered this and have been rewelded many times.
I added this rear bar to help spread that force and has held up great and I haven't had to repair it anymore.
I would also look into some engine risers. That chain wrap on that little sprocket looks a few teeth not enough IMO.
Some square tubing and a few holes is a good method.
I could be wrong but I think the camber/caster is zero on karts.
A few degrees of caster won't hurt but too much will cause the tire to lift the kart. Makes it hard to steer when your lifting the karts weight.
Just make sure its symmetrical in all directions and you'll be fine.
Looking at your pictures, it looks like a common predator 212cc engine. Looking closer,
I see a sticker that says 49cc. I didn't know they manufactured an engine that small.
Is that just a bogus sticker ?
Had always thought that the 79cc was the smallest. Is a 49cc engine with a centrifugal clutch even going to move his kart? What is the horsepower rating on that. It can't be putting out much torque with that small of displacement.
Rusty wrench
Just make sure it’s symmetrical in
Ya just a bogus sticker … that would be one beefy 49cc motor if not
Too bad you added the fun sticker before clocking your recoil starter to 10 o’clock. I try to have it rearwards where all the other knobs are (fuel switch, choke). No biggie
Deuce
Redneck in a White Collar
North Carolina
I have a live axle USA Industries kart from the early 2000s. By then it seemed they had started to think about camber and caster. It has a noticeable amount of positive caster (top of spindles tilted to back of kart), I'd say 1-3 degrees. Likewise for camber. 1-3 degrees positive (top of tire tilted inward). I can take a pic if it would help, but that's pretty much the setup. I use a pretty neutral toe with this. Maybe a fraction of a degree in. With this setup, it drives pretty well on pavement without much shimmy, despite being a trail kart with big knobbys. That said I don't disagree with others that everything neutral is the old tried and true. My Manco kart is set totally neutral and steers great.
