Jeffn
I'm new to the forum - actually found this forum while trying to identify the go kart we just bought. My oldest daughter wanted to "rebuild an old gokart" with me, and my 12 year old twin daughters wanted to learn to drive before they turned 15, soooo we started looking for something with a cool vintage look. I've determined it's a Clark, either a 440 Cyclops or 460 Rebel (it does have orange paint under layers of white, black, and pink).
I have a few questions for the Clark experts out there:
The motor is a Robin that's coming off and being replaced with a 4hp Kohler K91 from the early 60's that my father in law had sitting in the shed waiting for a project. Just need to rebuild it. The floor pan is rusted out and needs to be replaced, but other than that it just needs to be cleaned up and painted.
I also may have a bead on another Clark 440. There's a frame listed locally, and another seller that has a set of manco wheels among other odds and ends go kart parts. Anyone interested? If so I'll see what I can find out.
Thanks for your help!
- Does anyone have a pattern for the original seat cover that I could use to create a new one?
- Can someone post or send close-up photos of the linkage from the pedals back to the point the rods connect to the cables? I've only got one and it's not correct. I figured out how to make my own, but want to make it as original as possible.
- Could the kill switch panel below the steering wheel be original? It's riveted to the back of the hoop, but it's pretty well done - doesn't look like a backyard job.
- The tabs to each side of the seat look like they were for a seat belt. I don't see them in any other photos of Clarks I've found. Could they be original, or are they just an add-on?
- The pedals look original and I've seen them on other Clarks. I've also seen pedals with a serrated surface that have "Clark MFG" cast into the side. Were both types used? Are the serrated pedals older?
