chopper build up
dan
Austraila
hey all, ive recently been doing up a 200cc briggs flat head as some of you may know. then i thought to my self hang on a minute i dont have any thing to put the engine in so i thought to my self "id like a sleak chopper to cruise around on". so i set off building my little chopper.
this is what i have in mind for gearing straight driven 15t front sprocket and 52t rear. its running a 13" wheel with a small car tyre. let me know what you think.
here are the pics
cheers, Dan
robbie
Osceola, Missouri
According to the speed calculator on this site your bike should be able to go 77 mph. I read the numbers on your tire and looked up the outside diameter online, and I assumed 3600 rpm on the engine, although I'll bet yours will be faster. You may want to gear it slower for better acceleration. I'd want some shock absorbers for such a fast bike.
Other than the lack of suspension, I like your frame. It looks pretty cool.
Imbo
Young Mechanical Genius
Garden City, NY
if robbie is rght about that 77...i would not trust it....i would go for gearing near 13ft 55rear...the speed like that is insane....also your acceleration would be horrible with a possibility of burning out your engine. if you could get a TC that would probably help alot with acceration and speed
dan
Austraila
front tyre is plenty wide enough, i have a lot of trust in my welds and fab skills as this is what i do for a living. as for the speed factor i dont know.
robbie
Osceola, Missouri
http://www.diygokarts.com/speed-calculator.html
That is from the link on the bottom of this page, where it says DIY go kart and mini bike home page. According to the info I found on the web, your rear tire is 24.9 inches in diameter. Put your numbers in the calculator and adjust your tooth count until you get a speed you think is practical. If you gear for too high of a speed, you'll fry your clutch. With a non shock absorber frame you may want to keep the speed under 40. Otherwise you could hit a bump in the road and go flying.
dan
Austraila
there is no clutch. may be building a 2 speed box for it tho
r97
Measure twice cut once
Massachusetts, USA
no clutch? direct drive? that ratio is a bit high, may be able to manage with a 2 speed, but usually torque = more fun than speed
nice shop!
robbie
Osceola, Missouri
Were you thinking of having a direct drive from the engine to the wheel with no clutch? Or do you have some other plan in mind? A 2 speed gear box would be cool, but in that case you would need some kind of clutch.
dan
Austraila
well as i have a cracked fly wheel i have no engine. does any one have a 200cc 6 hp briggs flywheel?
brendonv
Australia, Perth
Car tyre on the back! Man turning will be ****. You will have hardly any grip. Also because you got such a wide tyre on the back and a small one on the front, when you turn you will be turning a smaller distance on the front and a greater distance on the rear. A wider front tyre will make it go a lot better. It will turn like poo the way you have it. Also because a car tyre is flat, you will be rolling the front tyre and sort of have like 1cm of bite on the rear.
sideways
Unfinished projects king.
Perth, Western Australia
With direct drive and that super high gearing you will have to get it rolling about 20-30kms before the engine will start. You need to gear it down.
Thanks
Hayden
dan
Austraila
and its a roller :) very happy all looks to be well little bit more machining tomorrow and my axle will be sweet as. goin to have to run the sprocket and chain on the out side of the frame :/. should be all well tho. heres some pics.
cheers, Dan
sideways
Going to mill any fins into that head?
Interesting placement of the spark plug, to say the least.......
Post some pictures of the head please, I'd like to see the combustion camber.
Any lawnmower flywheel from an engine of that block size should fit, as long as they were fitted to a mower with the same type of pull starter and one without points.
Thanks
Hayden
dan
Austraila
sorry heads strictly top secret...... nar jokes. why do you think the plug placement is strange? and no fin to be milled in to the head, tho i was thinking of running water ports in it to water cool it.
dan
Austraila
heres what the bike looks like now,
this is what im goin to make it look like tell me if you think this looks better,
