Thepartsguy
- Messages
- 1,452
- Reaction score
- 1,322
Ahhhh crud I’m late anyways I have questions myself. You do have the jackshaft sleeve that stops the bearings from side loading when you crank the nut on each of the jackshaft tight?
The only local option I can give you is PA has tractor supply’s they have a hardware section with 3/4 standard and heavy duty axle spacers. I think they were $3 I would buy one and cut a small shim it buts up against the bearing and spaces the driven pulley from the bearing.
(As an example don’t cut down the actual parts you have) The parts circled in red cut a very small piece off the end and use as a CVT pulley spacer in between the bearing and CVT driven.
