changing to torque converter
conconinc
Hi Guys I have a Manco Eliminator 435b that is a single wheel drive and seems like I am always changing the centrifigual clutch can you tell me if it would be better with a torque converter? I was told by someone else that if it was single wheel drive it wouldnt make much difference. I have a gravel driveway that we drive on it is a hard surface but it seems like it takes off too slow.
Jake.B
California-USA
Sounds to me like your geared to high. High gearing usually burns out clutches and slow takeoff makes me think it even more. What is your tire diameter, clutch sprocket size, and wheel sprocket size?
conconinc
Clutch is 10 teeth
Jack shaft from the clutch is 23 teeth
Jack shaft to the axle 12 teeth
Axle 17 teeth
140/70 x 6" tires
I am sure you are right but don't know how to get it right without guessing and the gears are to expensive to be guessing. Mostly just the grand kids are driving it up and down the driveway which is about a 1/2 mile so I am not looking for a lot of speed just enough torque so as not to burn up clutch. I thought the torque converter would be good because I might be able to control spped a little bit and maybe upgrade the go kart later when they get bigger and put a live axle on it if you think that is worth it.
OK....you have a serious gearing problem. What you have now is (23/10)*(17/12) = 3.25:1. To be geared at 3.25 is waaaay to high for a kart. You kart should be geared at least 6:1 for any sort of performance and torque. Your high gearing is why you are burning up so many clutches.
To get to a gear ratio of 6:1 there are many different sprocket combinations you could use. If it was me, I would go straight to the axle sprocket and change that to around a 34T sprocket. This will give you a ratio of just over 6:1. It shouldn't be too expensive. All you need to do is get the right bolt patter, or drill your own to make sure it fits properly.
If the diameter of a 34T sprocket is going to be too large for your tyres, then you are going to have to look at changing one of the other sprockets.
I would suggest that you take some pics of your drivetrain and post them here so that we can see what everything looks like, and what the best options would be.
As to the torque converter, I wouldn't worry about getting it now, as you have a dead axle. When you upgrade to a live axle, a torque converter becomes an option
I am pretty sure you will be fine with a centrifugal clutch with better gearing though. As long as you are not going to be doing major offroading or changing to larger tyres.
anderkart
Surprise Arizona USA
Clutch is 10 teeth
Axle 17 teeth
140/70 x 6" tires
Yeah someone has radically changed the gearing on your kart to achieve a higher top speed.
This first link: http://www.tricountysupply.com/pdfs/IPLs-435_436-435B436C13447R5.pdf shows your kart originally had a:
10-tooth clutch,
23-tooth jackshaft In,
9-tooth jackshaft out,
27-tooth axle sprocket.
So you need this 9-tooth jackshaft out gear:http://www.gokartsrus.com/8720-sprocket-420p-9t-integral-key-1125s-p-3466.html
And this 27-tooth axle sprocket w/drum assembly:http://www.gokartsrus.com/product_info.php?products_id=5362
This will restore your kart back to its original gear ratio of 6.9 to 1, and result in an estimated top speed of 20mph at 3600rpm with your 14" tall rear tires.
conconinc
Thank you I will start with original and go from there. I traded this machine for some money a guy owed me and have replaced about three clutches. I think this will work and having the parts manual will help out a lot thanks for your help. Once I get everything installed will let you know how it turns out.
