Chain question
mrm143
I need to buy a new 41 chain
My question is, are they all the same length or do i actually have to measure mine?
I have a 10t/60t Setup
And should i go with MFGsupply, (slow shipping) or another company that you guys recommend
brendonv
Australia, Perth
They come by the metre in australia or for u guys in 3 foot lengths or something. A metre will be plenty, just grind off the link where u want it cut and pry the link off. Keep the rest of the chain incase u need to lengthen it or something. I just got a new engine on mine and needed like 8 more links, that bit extra comes in handy. Saved me like 15 bucks in new chain.
mrm143
So it's not a one size fits all kinda thing, but 3feet should be fine?
anderkart
Surprise Arizona USA
For several reasons most karts use different chain lengths. 3 feet should be long enough for most any kart but you could measure your old chain, or around your sprockets if necessary to be sure.
brendonv's method would work, or you can use a small punch to drive the links pin out at the correct length. Then use a master link to connect your chain together. (install your master link with the closed end leading in the direction of the chains rotation)
Another method is to use a chain breaker made for your #41 size chain to press the links pin out (at the correct length needed) and then press it back in to make a one piece chain without a master link. (this is how I do it and here's some for sale online: http://www.google.com/search?sourceid=navclient&ie=UTF-
EagleTalons
Master JB Welder
Forsyth, Montana
Chain breakers are a great investment for your tool box. Saves alot of time fiddling with the chain itself and gets the job done in seconds.
mrm143
Will the chain breaker also pop the pin back in so i can not use the master link, or will it only remove the pin...
And if not, how do you put pin back in
anderkart
A chain breaker has 2 functions. It will push the links pin out (and then you could use a master link if you wanted) or a chain breaker will also push the link pin back in so you dont have to use a master link at all. You end up with a more trouble free chain this way.
A good quality chain breaker made for your size chain is designed to only push the pin out far enough to get that link apart. The pin will actualy stay in one side of the link.
solomon
ca
master links r cheap so buy 1, grind the link and use a punch on them and they fall right off. simple as that. today i need like 3 feet of chain and i only had 2 short chains so i spliced them and grinded some links
Fawteen
Old Pharte
Downeast Maine
I rode motorcycles for a LOT of years, and can't recall ever having a master link fail. The bikes I rode (especially with my fat arse on them) had quite a bit more weight and a LOT more horsepower than a kart.
My point being, I don't see where a riveted chain has any particular advantage over a master link system, and to my mind the master link is a lot easier to deal with, particularly if you have to take the chain off at some point.
mrm143
I also ride motorcycles, and i know one time my master links ALMOST fell off, thank god someone noticed it, the dealer riveted the chain so no more master link
solomon
ca
yup use a master link and grind off the excess links on your chain. Most atv places sell chain for about 12 bux pre 3ft
1992suburban
I wanna go FAST!!
Sanford, NC
BMI Karts
look them up, chain is $1 foot and master llinks are like .60 cents!!
thats where I bought mine from... Lowes Might have them I know they sell chain and masterlinks.
Northern tool is where I got some 35 chain from as well
if you were close to me I would tell you to come get what I have I wont use it..
mrm143
Lowes had em, in the very BACK of those drawers with the links, but didnt have a 41 in stock... So just a heads up for anyone goin to lowes, they had from #35 up to #60 i beleive
frederic
The Junk Man
New Jersey
Different Lowes stocks different chains. The one closest to me only stocks #40 chain and #40 master links. That's it, no other sizes, though they're happy to order it for ya.
Another Lowes about 20 minutes from here has two drawers dedicated to chains and links. #35, #41, #60 in stock, with the ability to order other sizes.
I found it interesting that they carry different stuff.
motor_head
expert garbage picker
sutherland IA
just go to a local shop they will prolly have all the chain you'l need near me is a place called triple R good welding/ metal work shop have just about any thing you need just find a place like that near you
1992suburban
I wanna go FAST!!
Sanford, NC
also are all 35 chains made the same..
example Now I know how long of a chain I need can I buy the same length NAME BRAND CHAIN like DID (think thats what its called)
sorry for HIjack
