Chain falls of on a turn?
newrider3
Colorado
Wow. I've seen skip-tooth sprockets before, but that just seems like an odd thing to do to lose such a small amount of weight.
Also, why is there a water neck attached to your carb???
mzg
The sprocket is good, but I think I agree with the fact that it can move a lot, so the first step that is should do is change the sprocket ?
mzg
I have 2 other sprockets that the person included with, 53 & 60 tooth. I should put those on?
mzg
okay, so I need a new chain, replace sprocket and how often should I change my oil?
mzg
Okay thank you. I will let you know how it turns out as far as changing the sprocket and chain see if that solves the problem.
mzg
okay i will let you all know how it turns out after I replace a few things on it and make sure that everything is tight on it. Also how much oil goes into my cart any idea?
mzg
Does anyone live near Homer Glen IL ? I could use some help I am not good at working on my go kart what so ever:(. Thinking about fixing it and selling it if anyone interested shoot me an offer I paid 1k.
anderkart
Surprise Arizona USA
I have an Idea that would make replacing your sprocket much easier. Looks like your current sprocket is a 1 piece and you'd normally have to do a lot of work to remove it.
I saw you said you had 2 extra sprockets, are they 1 piece or split sprockets like the ones for sale here in this link? > http://www.cometkartsales.com/store/hrstman/ssg.htm
I just wanted you to know you could cut your old sprocket off with a hack saw and then simply install a new split sprocket without having to disassemble your rear axle. If you decide to buy a 2 piece sprocket, you'll find this link: http://www.gokartsupply.com/chain.htm has some info to confirm if your kart is set up for #35 size sprockets or not.
mzg
Im not sure if the current one is a 1 or 2, but I do have 2 other sprockets that are in 2 pieces. As far as a chain goes i purchased a #35 roller chain today and Hope it works for my kart. The chain that is on the cart now is a #35 but seems like its a better chain feels much thicker then the one i bought which is the same size.
mzg
GOT THE KART WORKING GREAT:) I put a new sprocket on, with new chain, Chain is really tight now and does not fall of at all i will post some new pic soon for all to see, Thank you for all your help/ideas.
mzg
All fixed chain was way too loose fixed a lot on the kart so far.
mzg
chain still manages to come off once in a while but not much, should I put like a chain tensioner or something?
