Celerity Quicksilver Sport Coupe (EA racer)
I got 'er all bonded together :banana:
Close up of overlapping junction/seam
* See how the screws help to "clamp" the overlapping panels together
** The screws will be removed after the resin cures &/then, the holes will be filled in
An issue I came across, was in a couple of "spots" the screws ended up "grabbing" some FG fibers, from the "glue strip", during screwing
...&/then, "bunched" the fibers up into a kinda like "goopy cotton ball"
These "goopy cotton balls" had to be removed (which was a "goopy" PITA) :oops:
...because the "bunched up" material was actually "pushing" the panels apart
...&/so/then, I upgraded to 1/4" nuts & bolts ;)
A view of the body side panel, to floorboard, inner overlap (& bolting clamps)
* I must say...looks pretty clean...up in there :2guns:
I used the wooden "spines" to trace the shape onto a sheet of FG
...& I was able to get all (4) "spine" pieces, out of the FG sheet that I originally made, for the floorboard
Cuttin' 'em out
Again, I used a straight edge to help "guide" the long, straight cuts (makes a much prettier cut) ;)
All cut out
I want to bond the FG panels to a 1/2" foam board core
...but, many adhesives aren't compatible with foam board, like Polyester resin (mainly due to the solvents)
* I've seen folks (on YouTube) bonding stuff to foam, using Contact Cement (like the kind used for countertops)
...but, they say, you can only apply it to the "other" material (not directly to the foam)
...&/then, you must let the cement dry, pretty well (letting most of the solvent evaporate) before assembly
So, I as a test, "glued" a piece of 1/2" foam to some scrap FG
After a couple of hours, I didn't notice any issues with the foam
...& the pieces seemed to be bonded together, pretty well
Even when prying up on the edge, the bond seemed to hold good
But, when I did a "flex test"
...the result was complete FAILURE :ack2:
Next, I Googled "what adhesive is compatible with foam board?"
...& (1) of the results was Ultimate Gorilla Glue (available at Home Depot ~$13.00)
&/so
On my next tow, I stopped & picked some up :thumbsup:
I "glued" the same piece of foam
...to the same piece of FG
...&/also, another piece of scrap, to the other side
After a couple of hours, I tried prying, flexing & twisting the sandwich panel
...& couldn't even get any movement (which is good) :bannana:
Then, I wasa thinkin', let's try a brick test
So, I set up (2) bricks ~6" apart
...set the "test piece/sandwich panel" on top of 'em
...& then stood a brick up, on it, horizontally (the skinny way) on top of it
The panel still looks nice-n-straight ;)
Hmmm...how about (3) bricks (still looks ta be "unfazed")
Let's try (4) bricks (yup, still looks good)
OK, lets try (6) of 'em...wholy...crap :2guns:
Close up, of sandwich panel with (6) bricks on it
When, I went to put a 7th brick on...everything collapsed :ack2:
I thought the panel finally failed...but it didn't
...& I found it, to be, still intact :sifone:
Nobody ever listens to me.
Yeah. Clecos are nice.
Hey WTR,
I guess I missed that episode :confused:
...but, I'd like to know more about 'em :thumbsup:
How about some experienced, personal use info, on using these little "guys"?
Seems like the "moving parts" (3-piece clamping tip) may get "gooped up" with resin...if used for holding (2) FG panels together, for bonding
...& "they" would have to stay in place (to maintain the clamping force) until the resin completely cured...making clean up...more difficult o_O
More info...more info...I want more info :unsure:
