I got 'er all bonded together
Close up of overlapping junction/seam
* See how the screws help to "clamp" the overlapping panels together
** The screws will be removed after the resin cures &/then, the holes will be filled in
An issue I came across, was in a couple of "spots" the screws ended up "grabbing" some FG fibers, from the "glue strip", during screwing
...&/then, "bunched" the fibers up into a kinda like "goopy cotton ball"
These "goopy cotton balls" had to be removed (which was a "goopy" PITA)
...because the "bunched up" material was actually "pushing" the panels apart
...&/so/then, I upgraded to 1/4" nuts & bolts
A view of the body side panel, to floorboard, inner overlap (& bolting clamps)
* I must say...looks pretty clean...up in there
