FatCat
2 stroke Addict!
Hi guys, I got the 16hp vanguard bolted up in my Carter mini monster. It's a tight fit but it will work. Now I'm working on the jackshaft setup for the secondary clutch. I've got a plan that should work good. I did not like the original setup. It was for I believe a 5hp engine. Seemed very light duty to me. The shaft is only supported from one side. since I'm going to a 16hp engine and I'm rather heavy I want to beef this up. I'm thinking a pillow block(think that's what they're called) on each side of the jackshaft and locate the keyed secondary where I need it on the shaft with lock collars. So I'll need a longer jackshaft and one that has a keyway the full length. Does anyone know if these shafts have a keyway the full length. It's a tad long but I can work with it. I didn't see it in the description and I can't visually see it in the pics. Or where I could get the correct one?
http://www.mfgsupply.com/gomini/gominiaxles/gominijackshaft/gominijackshaftonly/az8183-10.html
This is my first go kart so I'm not familiar with this stuff at all. If my idea could be improved on or you know of a better idea I'd like to hear it. Thanks!
