fowler
arr right i thought it would be dew to its lack of use
I read this thread with great interest, just thought I'd add my 2 cents...
As has already been mentioned, starter motors get smoking hot in a very short amount of time. However, I would argue that this is because they're (almost) always operated at very high loads. Turning an engine over is a big job, if you've ever barred an engine over with a ratchet or breaker bar (even with the plugs out!) you know what I mean.
Anyways, there's 2 ways I can think of to make a starter motor useful as a prime mover:
1) Use a MOSFET motor controller, which you can buy turn-key and ready to go, build your own or scavenge from a golf cart or electric forkilift or something
2) Use a CVT, like those little Torq-A-Verter things for go-karts, or scavenge one from a snowmobile.
The main advantage of a CVT is that it allows you to use the OEM solenoid to activate the motor, no throttling necessary. It'll also accelerate smoother than a direct-drive setup. One of the engineering co-op students I worked with a couple years ago built a little kart powered by a Toyota Corolla starter, and man was it a neck snapper! He said he ran it at 24V just to try it and it was so violent & uncomfortable to drive he almost vomited, so he wired it back to 12V
My 2 cents. Your mileage may vary
Good input, but I think starters still over heat even when not under load from turning over an engine, if its prolonged use (over 30sec-minute)
Trust me, I wouldn't have registered an acct just to lie to you all! Lol
. My STARTER pulled me into the truck stop while I grossed out at....wait for it........79,000lbs!!! And it pulled me UPHILL!!!
So, for Anyone who didn't believe the guy who said his starter pulled his car in 3rd gear, BELIEVE IT!!!
