Car Starter Motor
anderkart
Surprise Arizona USA
Not while cranking an engine but I'm thinking it'd have enough torque to wind out pretty good on a light kart. Heck its got 5" tires, this must be a micro kart.
gokartmozart
Pittsburgh, Pa
Yeah, it may move a car, and I have known people to move their broken cars off the road by cranking with the car in gear. But, remember there is a 1:12 gear ratio there.
I know just from experience, talking to a hot rodder here, that rotating a mild compression six cylinder engine with a wrench takes quite a bit of effort. Those little starters got some kick.
But, know one has a idea of good starting gear ratio?
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
It moved my car in third gear.
Just remember that automotive starters and batteries are only designed to crank for 15-30 seconds. Starters get pretty hot after repeated cranking.
Bluethunder3320
it can move a car in gear????? is that even possible???? wow. i would go for a 5 or 6 to 1 ratio or somewhere around there...
devino246
Lynchburg, VA
Only on older cars that lack a neutral safety switch. Newer cars have a switch in the transmission that disables the stater when in gear and doubles as a backup light switch.
Bluethunder3320
yea, im just suprised that a starter has enough power
Crossing topics with another thread, every now and then the clutch seizes on the Ford 575 tractor, and I have to start it in gear.
And since you're wondering (and I know you are), I cruised an old tractor forum- very common on those machines. Crappy design. Basically, you have to get some speed, then while holding the clutch pedal down, mash the brakes sharpy a few times 'till it breaks free.
Back to the torquey starters thing, not only does your average starter have enough oomph to push a vehicle, it can often do it quick enough to start the engine while doing it.
Years ago, I was driving my 1977 Celica home from my parents place, and the clutch slave blew out in an intersection. I made the 30 minute drive home with no clutch, partially by starting the engine in gear.
devino246
Lynchburg, VA
Sweet! Your starter must have been trashed.
gokartmozart
Pittsburgh, Pa
I can easily mount this starter with a 1:2 (I have some sturdy cam gears) once I fab up my kart. So I will consider it a kinda experiment. With only small 5 inch wheel it should rock.
anderkart
Cool, I'm still not sure how many rpm that starters gonna turn, so yeah gear it with what you've. I think this is a cool project!
I'd start out with some short rides and feel how hot your starters getting, If yer fingers start sizzling like bacon you'll know its probably time to let-her cool down a bit :D
Not at all. Over the whole trip home, I think I started in gear twice. A few times I was able to slow down well ahead of a red light long enough for it to turn again. One stop was on a downhill slope to I was able to start rolling forward in neutral and nudge it *gently* into first.
Without a clutch, upshifting is pretty easy. Downshifting is a tad more challenging. But being able to start rolling and nudge it into gear without grinding amazed me. Downshifting into first was a little tricky, too. It's all about matching engine RPM to wheel speed.
gokartmozart
Pittsburgh, Pa
Once my engine siezed and I cranked on it a few times, and after I rebuilt the engine I thought I had a battery issue. I kept jumping the car, and once I got a new battery I realized the starter was not functioning at 100%. So, I guess a starter can become less efficient, or shot. I mean the starter still cranked but not with the effort it had.
Just sharing my starter knowledge/experience.
Sorry, we kinda meandered away from the topic. I do think this is a case where it's best to gear it with what you've got, and do some seat-of-the-pants testing, then adjust ratios to suit.
fowler
Bullsbrook West Aus
just on the over heating thing.
in a davesfarm vidio he says removing the solinoid on a starter makes it better for kart use.
i dont know if this is relivent but it might be the reason it over heats.
also when i bulit and raced electric karts at school one other team put there engine in a modifyed esky and filled it with dry ice to finish the race (not the most practical idea or the cheapest but a surgestion)
devino246
Lynchburg, VA
Dry ice isnt very expensive. A good size chunk is like $8
