Car audio Help...
Hey guys...
Now Im wanting to get the radio working in my "new to me truck"... The PO had installed a deck and it by all means seems to be correct, powers up and functions work... Just no sound...He said it was new( I know the guy and believe him)
'92 nissan pickup D21 hardbody single cab..
Now I removed the dash panel and looked at the connections.. all seems correct.. so Im guessing the speakers are shot..... fare enough...
Upon looking at the deck it has a number of RCA type connectors labeling to speakers L-R and to amp ect... Its a clarion cz302.
Now I have an amp/sub( just not installed) A Rockford Fosgate prime r600-4d amp and a Kicker 12" with box, but there isnt really any space behind/under the seats for those, so Im not caring about that... But I do want some kind of sound...
I want the new speakers in the lower foot well side panel area( for lack of a term), not in the door(so i'll just leave the OEM ones alone)..
Am I able to just connect with RCA plugged wires to the new set of speakers Im looking to get? Or do I have to wire power/ ground to these aswell???
Looked to see what connectors are out there.. confused:eek::eek::eek:...
This is really a new thing for me and I haven't been able to get any info on this for DIY or new automotive audiophiles...
Randy H
The RCA plugs are intended to be plugged into an Amp.
I saw that... There is 2 for front channel L and R...
Am I able to use those and plug/play for 2 speakers?
anickode
S.E. Michigan
No, those will be line level outputs. You would be lucky to power a set of earbuds off those, unfortunately.
anickode- Ok... what does that mean exactly?
So the best way is to just disconnect what is there and check with a known working speaker, and re wire with soldered connections to the harness that is supplied on the back of the deck???
Im sorry this is just a new thing and I barely understand it...
Should have a built in amp. 45watt max (19watt RMS) x 4 channel.
The wiring diagram above shows how to wire the speakers directly from the head unit.
I have a digital... Will that do??
What about a light?? Will it flicker or just stay lit?...
Joe-405
Enjoying New Projects
U.S.A.
Those wires the speaker attaches to............ just pull the head unit out and wire them direct to a speaker while it’s sitting in your lap. That’s what I used to do at the car audio store when I was installing.
---------- Post added at 08:04 PM ---------- Previous post was at 08:04 PM ----------
If it don’t work then the internal amp is bad in the head unit.
anickode
S.E. Michigan
It doesn't have to be a car speaker either. A small bookshelf speaker, or even a big stereo speaker will work as long as the impedance is greater than 4 ohms.
Ahhh...I'll try that...
Any ideas on a set of speakers... About 4.5-5"... I could see about $100 all together.. Wires and such...
No other amp used.. The deck has an internal amp as far as I can tell..
Bob- these three way speakers you speak of... Are they wired separate or all in one set of wire???
Edit: WoW... NOOBish.... ill say.... So I took a look and yes... they are all in one speaker, with one in/out terminals for the wires....
Sorry guys... I guess it is easier than it looks.....
Ill look over some speakers and see what I can come up with....
How / Where are these going to be installed? I know you said you plan to put them (somewhere) and leave the factory speakers in place. I just can't picture where they will go.
Are you going to cut a hole for them in the kick panel? Or build an enclosure?
If it were me, I'd probably replace the factory speakers with ones of the same size.
Here is a picture of a "kick panel" speaker enclosure.
Search Nissan Truck kick panel speaker enclosure.
https://www.hifisoundconnection.com/Shop/Control/fp/tcat/111541/SFV/30046
It's been two decades since my hobby was car audio. I used to go to the flea market every week to see what was recently stolen and being sold at a discount. LOL
Used to have one 4 channel amp to power two 6x9's and two 6-1/2". And another 1000 (or 1500?) watt amp dedicated for my two 15" subs. I think I only used the head unit to power the 4 tweeters I had (bass clips to prevent the low tones from playing through the tweeters). Crossover, 1 Farad Capacitor, ..... My stereo was worth more than my car.
