Can't open my pull string to fix the string
Kengthao91
Here's two pics of my pull start and wanna see if anyone know how to take it apart to get into the spring... The string broke and I tried to rewind it but it doesn't work or have any tension.... Seems like there's something that's is wrong with the spring........
The only thing wrong with the spring is it lost its tension when the string broke.
Can you post some pics that aren't so close? I think I can help you but, I need to be able to see what I'm dealing with
Kengthao91
Pic
zbuck
Ft. Wayne, IN
:wai: Unfortunately,that pull starter is not made to be repaired. They are consider to be throw aways. Only option is a new one, either OEM/A.M. I know I am going to catch some flack, but I have tried every trick in the book to repair them.
Kengthao91
Yeah I also try hitting with a hammer/flathead.... But can't get the hole to close to take off the housing.... I also tried searching for a new one, but can't find it
zbuck
Ft. Wayne, IN
:wai:Why the hitting it with a hammer? Post the engine numbers and I will see if I can come with the PN for the pull starter either OEM/A.M..
Anything can be fixed, you just have to work out how :)
Can I assume this is off a predator or other honda clone?
Have you looked for honda replacement parts?
Is part of the string still attached to the centre?
Where/how is the string attached on the inside end?
If you wind the carrier counter clockwise does the tension build up at all (it may take a few turns)?
Does this help at all? http://www.youtube.com/watch?v=OgJCdrnCnwg
zbuck
Ft. Wayne, IN
:wai: In that video, there is a bolt holding it togehter, easy repair. The on the one that Kengthao91 posted, it has been crimped/swegded over. Like I stated throw away. Also just another way for the engine manufacture to get more money out of us.
Kengthao91
I don't think you can fix it also.... I've tried many ways to try to get into the spring, but nothing works.... So the last thing I did was torch that crap to see if I can close that cramped/hole part.... But end up messing it up so I just threw it away and order a new one.... Hopefully it fits :(
Agreed! I have serviced a zillion "non-serviceable" things over the years. Sometimes it a matter of cutting/grinding/drilling something apart and gluing/riveting/welding/bolting it back together when it's all said and done.
For a shop, yeah- pitch it. For a DIY-guy on a budget, such as myself, well- it gets fixed.
Since a "shop" as a general term is an environment wherein a client pays for parts and service, then that's a bit of a game-changer, no?
Bottom line- I don't care how somebody else spends their money, but I'm pretty careful about how I spend mine.
Cjhoward78
I could fix this recoil starter!!!!! Lol!! u guys are great:) where's my popcorn.....
zbuck
Ft. Wayne, IN
:wai:Toystory_4wd, on the game changer part, yes and no. To be Honest and Fair to my customers. If the new part cost less than my time to repair it, they get a new one.My shop has a budget to, you have to remember that my money is on the line when buying replacement/repair parts. As I do not get paid until the customer pays. I also understand about the DIY'ers. Fabroman, on a 200$ part, it would depended on how much damage and time wether to replace/repair. But to answer your question, yes.
I understand. I have to make the same assessments when I do this stuff for paying customers. Not my bread and butter, but you can well imagine that folks come to me from time to time to fix their junk.
What I was getting at was a personal, non-business, hobby standpoint. Yes- I would just just fix the recoil instead of buying a new one.
zbuck
Ft. Wayne, IN
:wai: TS, hope you do not mind that I short cut your handle, I quess I could call myself a DIY'er, as I maintain my own equipment. Talk about junk (well worn equipment) you should see some of stuff that comes into my shop. I even have Dealers send me customer's, because they do not want to deal with the older well worn equipment. I also understand your statement on personal, non-business and hobby stand point.
I don't mind at all! We all have opinions, and they do differ sometimes- nothing wrong with getting into a debate!
As long as the "argument" (see classical definition) doesn't get into personal shots or general idiocy, then it is certainly welcome.
