Your zip ties for clamps might be a problem, you could have a vacuum leak somewhere. What are you using for line? I recommend Tygon for everything.
Except for the pulse line if its going to be any longer then 5" or so.
i ant to familer with fuel pumps on small motors but i though they were on electric start motors that when you are turnin them over they keep a pretty good vacuum goin to keep the fuel pumping strong. If you got a pull start motor you might not be keepin enough vacuum to keep the fuel flowing. i ant for sure though. Zip ties do hold good i use them on stuff a bunch. Do your lines fit tight on your little push on things on your fuel if you get what im sayin. Ima grab a chair, sit down, and learn on this one.
i am sorry about my speaking. i do appolojize but i don't know how to spell some/ allot of words so i just type them like they sound. i will try to do better.
Thank you for the tips. They are appriciated.
But don't the fuel pump need a pretty good constant flow of vacuum to keep it working right? What i mean is a constant purging of the airflow.
What kind of motor are you using? It might not have enough vacuum or be pulling enough vacuum to work the fuel pump???
