eveready077
- Messages
- 2
- Reaction score
- 0
i have a go kart with a jf168 jiangdong and i can't get it to idle and will not run with out the choke on some can you help me? thank you
The easiest thing to check is make sure your 2 carb mounting nuts are tight. If they're loose it'll allow the intake gasket to leak, (sucking in air) causing symptoms exactly like yours.
Its also fairly common to find the factory or someone else mistakenly installed the intake gasket upside-down. (that's the gasket between your carburetor and engine) This can also cause it to leak even with those 2 carb mounting nuts tightened.
Then if you still have the problem, you'll find lots of info to fix it
at this link:--> http://www.diygokarts.com/vb/showthread.php?t=10957
