can't get motor to idle
eveready077
i have a go kart with a jf168 jiangdong and i can't get it to idle and will not run with out the choke on some can you help me? thank you
The easiest thing to check is make sure your 2 carb mounting nuts are tight. If they're loose it'll allow the intake gasket to leak, (sucking in air) causing symptoms exactly like yours.
Its also fairly common to find the factory or someone else mistakenly installed the intake gasket upside-down. (that's the gasket between your carburetor and engine) This can also cause it to leak even with those 2 carb mounting nuts tightened.
Then if you still have the problem, you'll find lots of info to fix it
at this link:--> http://www.diygokarts.com/vb/showthread.php?t=10957
klicky96
Sandusky, Ohio
Also, check the idle-adjustment screw. Turn it in(clockwise) about 2 turns, start the engine up, and turn it counter-clockwise(out) slowly until the engine idles just right, then turn the screw in 1/4 turn.
joshkidner
West Michigan
ive had that happen on a snowblower (only runs on choke stalls after taking it off). i took the carb apart and cleaned it out real good (there was some junk in the bowl) and put it together the way i took it apart and wala! worked like a charm. hope that helps ya
eveready077
thank you
thanks for the info but i still have the same problem
It sounds like your idle circuit may be blocked. Take your carb apart, a lot of guys suggest boiling it in lemon juice (you'll have to research that one; search the forum).
If that doesn't work you may have to source a new carby
kendelrk
redneck engineer
westland michigan
take the carb apart as far as you can, leave the float, and all rubber parts out and boil in lemon juice for a half hour. if you dont have your own house you may want to do this while your parents are gone and then spray febrezze everywhere
