2SlickNick
American Minibikes @ FB
Hey guys,
I recently pulled the gov on my 6.5hp clone.
Put everything back together reset valve lash at TDC.
Occasionally now on about every 3rd pull the pull cord is pulling back hard.....
Once started it runs as it should.
I have read this it the compression relief mechanism causing this.
Is this true?
So...Back into side cover huh?
Can I or do I pull and remove the mechanism or just adjust it?
Here are two links
I used.
http://www.diygokarts.com/vb/showthread.php?t=17377&highlight=valve+lash+pull+start
https://www.youtube.com/watch?v=YLcO84W2So0
Is this true?
Here are two links
I used.
