Caliper bracket
dave1701
Good for 100,000 Miles
MICHIGAN
No I mean I'm going to have a welder, meaning a actual welding machine... The people "welders" will be me and my friend, both with just enough welding experience to keep us from hurting ourselves. I think I'll just buy one.
redsox985
PA
Try something like I did. I used 2 pieces of either 3/16" or 1/4" flat iron with holes drilled to that the caliper would rest at an angle and grab perfectly.
dave1701
MICHIGAN
Do you use the two bolts at the top of the caliper to hold it onto the bracket?
JHen
I have that brake caliper, and having it float would be better since one of the pads does not move relative to the caliper. You would get the best braking if you let it float. The brake rotor will keep it on the mount.
redsox985
PA
This is a good point, I think you should go with the actual one. But for mine, I just found 2 bolts about half an inch or so longer and slid them through. Mine still has some good stopping power and can squeal the tires when locked up.
