build off entry:purple monster
r_chez_08
Should be in the shop...
Cornwall, UK
Should be alright, but be careful for tight spots. I had to redrill some mounting holes on a sprocket and my sprocket was out approx 1-2mm from the centre and it caused tight spots on the chain, which if you tightened it at a loose spot, could have broken something. It had a similar effect to a bent J/S or axle.
Those welds look fine IMO, actually pretty good (better than mine lol)
gvfc2
wishing i was living
Tacoma,wa
lol all i did to get better welds was to turn up the heat. would relieving the tight spots by either having the chain alittle loose or have a spring chain tensioner with a light spring on it work? before the tight spots happen. but it might not work. if i get tight spots i guess would have to get a new chain and new sprocket but ill see in time
gvfc2
Tacoma,wa
yea im going to go that way too. seems better then a loose chain or a tight one with the sprocket slightly off center
gvfc2
Tacoma,wa
Well no updates as I have no money. I'm also out of internet which sucks. I should have some updates in the upcoming months as my 18bday is this month so I can find a job and actually have some money
