jrmints1415
uh oh i see a huge problem. is the main rails of the frame butt welded?? thats a big no no!
i do have a flat glass table that everything has been cut and welded on
depends how good or bad the welds are
a good welder should be able to cut a peice of metal in half and re weld it to be stronger that before
u better get a pic of that
not awful
more heat required
depends how muck more frame work u are adding
if u are adding more support and an upper rail then i wouldnt bother on this scale
just turn the heat up a little for the rest
That is looking real nice. What machine are you using? I'm sort of in the market for a new welder.
nm, I found a pic of it in the first post. Are you using shielding gas, or just running it with flux core wire?
hey, i really like that idea that you have with using the forks for shocks. Do you think that this same concept could be applied and used with mountain bike forks?
