Budget
JapMotors
North Daktoa
Hello I know briggs and hondas are sone of the best but I was wondering what you guys think about Tecumseh seeing as there are a ton of them (ohv) for sale locally let me know about reliability
r97
Measure twice cut once
Massachusetts, USA
Tecumseh engines can be great engines if you take care of them well (as with any engine). I will add that the flat-heads seem to be a bit better than the OHV models (quite frankly it seems the carbs are very temperamental). If you can get a correctly sized engine that is in decent shape at the right price I'm sure you would be happy.
klicky96
Sandusky, Ohio
I love Tecumseh, Briggs, and Honda. If I had a lot of money, I'd buy a briggs racer, but Tecumseh is a cheaper way to go if you are looking for a powerful engine. I have a 5.5HP Tecumseh OHV SnowKing, good engine, cheap, and runs amazing. The only problem is that it is a step shaft. Minor issue, but I used a homemade shaft adapter so that I could put my clutch on.
klicky96
Sandusky, Ohio
MTD is a company that build machines like lawnmowers, snowblowers, etc. Tecumseh MTD is just classifying that the MTD machine is using a Tecumseh engine.
r97
Massachusetts, USA
The first one probably has a good engine (check that it runs and has a 3/4" to 1" keyed straight shaft). The second has a tapered shaft which would need to be removed and turned down by a machine shop, or get a replacement shaft; then you would still need an expensive clutch. The third is a bit of a gamble, but if the price is right for you and your willing to possibly pay a little extra in repairs for a learning experience (engine could be trash...) I would go for it.
EDIT: if you are in the $200 range for an engine... look into Robin Subaru, excellent engines that (in my opinion) meet or exceed Honda in everything but hop-up parts availability.
http://robinamerica.com/series.aspx?sid=7
http://www.ebay.com/itm/Robin-Subaru-Engine-6-HP-Free-Shipping-/290677623328?pt=LH_DefaultDomain_0&hash=item43adbc8a20#ht_637wt_905
For more power search ebay for EX21, and EX27 (1" crank on 27)
JapMotors
North Daktoa
Ok I would like more hp but I know it wouldn't make much of a different I'll ask about the first one and what would be good hp for some one who weighs 180 plus a 100-130 lb kart in a slight hilly neighborhood
klicky96
Sandusky, Ohio
The third engine, you might as well leave that outta the picture because it sounds like its ready to blow a head gasket. Offer the guy $150 for the first motor and he'll probly take it.
