Briggs & Stratton Engine will not start
brazman007
Kansas City, MO
I just recently acquired a Thunder Karts XL700 go kart with a B&G 136202 engine on it that will not start.
I am new to small engine repair, so bear with me.
Here is what I know so far. I pulled the air filter off to expose the choke plate and sprayed brake cleaner in there and the engine started up in 1 pull and ran for just a moment while it burned off the brake cleaner. This tells me that I have a fuel supply issue.
I've removed the carburetor to see if it was clogged but I can't really tell. The engine sat for a couple years, so I know the gas is bad and needs to be dumped out, but I don't think I am getting fuel out of the tank because I did not smell gas when I removed the spark plug or air filter initially. I've also noticed that part 529A in diagram 2 below (it is a rubber grommet) has a tear in it. But I do not think that part is crucial to the engine starting.
Most of the gaskets are in pretty bad shape and dirty, but they don't appear to be in bad enough shape to prevent the vacuum being created to suck up the gas.
The diaphragm also looks kind of dirty, but not terrible.
My next thought is to remove the valve pin (173) to check to see if it looks clogged in there and maybe try to blow out the fuel line 611/612 with a compressor (these are part #s from diagram 1 below).
Any better recommendations on what to try next?
Links to part diagrams for the engine below for the carburetor group [1] and the cylinder group [2].
[1]
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=136202-0144-01&dn=07050008
[2]
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=136202-0144-01&dn=07050002
KartFab
Dallas, TX
buy a can of carb cleaner, the fuel straw thingamajigger part 611/612 should be blown out with carb cleaner, to help remove the varnish that has probably accumulated in there. If the straw looks yellowish/orange, then it is a good sign of varnish clogging up your carb.
If you are spraying carb cleaner in the bottom of that straw thing, you should see it blow out of the jet inside the carb.
spray a little carb cleaner/fresh gas in the gas tank and swirl it around, then dump it out. Repeat a few times. Tank inside could be rusty.
If you see any other holes in the carb, just blow them out with the carb cleaner too. Also it is always good to just replace part 394 if you are going to order anything
529A is just part of a breather tube that recirculates air back into the carb from the valve area. The engine will run just fine without this tube connected to the carb (its there just to reduce emissions and keep the engine compartment from over pressurizing while running)
qtband
St. Louis, MO
A rebuild kit is pretty cheap and the carb is easy to rebuild. Do what Gran Pann says about cleaning the carb, but I would get a rebuild kit and put in new parts. It'll run like a champ! Keep us posted!
solomon
ca
Take your time cleaning that pulse jet carb. Go through it very well. Its likely that your diaphragm on the side has ruptured.
Gokartbill
Atwater,Ca
After cleaning your carb out, make sure gas tank is full of gas. Those old carbs have trouble picking up fuel when its below half a tank
brazman007
Kansas City, MO
OK, I finally got the engine running after a few hours of leg work. Thanks for all of the responses!
Here is a breakdown of what all I found and what I did to get it running.
I bought the rebuild kit for the carburetor, which I replaced the intake gasket, fuel tank gasket, jet-pilot and the diaphragm. After seeing a new diaphragm, I certainly think it was a big part of the problem. I cleaned out the whole carburetor with carb cleaner, including the jet areas. The guy at the lawnmower shop explained how the carb worked in detail, so once I knew that I felt a little more comfortable with my diagnosis.
My other problem is that the tank is in bad condition on the inside. I cleaned it out several times as the initial fuel I dumped out was basically orange/red due to internal rust. I cleaned out the tank really good and have the gas looking normal now and was able to start the engine up and run it several times. I wanted to confirm it worked prior to investing in a new $90 gas tank.
After taking care of all of that it started up basically in two pulls and it runs like a champ. Now it is time to replace the gas tank and a few other items that need replacing to get it in perfect condition.
Thanks again!
qtband
St. Louis, MO
You may be able to seal the inside of that tank cheaper than buying a new one. I'm sure others will tell you how. Great news on the rebuild. pretty cool when you do that work and it fires right up!
solomon
ca
POR 15 is your best friend, or opt for a used tank in good condition. I know they can be had for >$50
qtband
St. Louis, MO
Fill out your profile so we know where you are located. Maybe someone on here is close to you and has one.
brazman007
Kansas City, MO
I filled out my profile, I am in Kansas City. What online sites have you guys ordered parts from before?
POR 15 looks like it would work fine. But, I don't think the tank comes apart, so I am not sure how I would get it on properly.
I would love to buy a used one, just not sure where to look in KC.
