Briggs and Stratton size?
nealolsen
Im trying to figure out what size briggs I have. It was on a Montgomery Ward edger but the shroud has no numbers on it and the edger model is zmy 161c I think some is scratched out. The block is aluminum, 8 bolt head and it has points. The bore is measured at around 2.371 and stroke is 1.5. I have looked through endless posts and even the briggs book and I cant find anything. It has a pull choke pulsa jet carb. Cant find any numbers stamped on anything. Any help would be greatly appreciated. I have attached the edger pic, model, and the block stripped down.
JTSpeedDemon
2019 Build Off Winner!
Texas
Sounds like a 3 HP.
I don't have my service manual on this device, but I can tell you that engine makes right around 3 HP.
What's your plans for it? As you can see in my signature, I am flathead crazed, and I love seeing other people keeping these engines going.
hmm.. sounds like a 10cui to me (3 horse)
mainly because 10cui are about 161ccm and 161c... *shrugs*
coincidence maybe
since
that thoughh doesn't match bore and stroke measurements :(
ps oops jt beat me to it :D
[EDIT]
yes bore and stroke for a briggs 60000
is 2.3740 - 2.3750 bore and 1.5" stroke...
2horse then IIRC
nealolsen
I'm building it for my sons mini bike. I picked it up for $20 bucks not running along with a 1967 2hp not running.
---------- Post added at 11:01 AM ---------- Previous post was at 10:59 AM ----------
I appreciated the help and info.
nealolsen
Im going to leave the governor off when i put it back together. How much do these motors wind up? I don't want to blow it up.
JTSpeedDemon
Texas
About 5200 RPM with the stock valve springs. Should be safe, but don't hold it there too long.
