Briggs 5HP fun power Governor
manco36
Heres some pictures. You can see the throttle on top is the one I was pressing to make the go kart go faster. And the one under the gas tank that the throttle cable attaches to is the one that is being pulled to its max (the end of that slot) when I press the gas pedal.
Any ideas on how to adjust the throttle on top to go in further when I hit the gas?
jamyers
Buffalo Gap, TX
I'm thinking the governor is out of whack, and not opening the throttle all the way.
While the governor parts/design varies on these engines, the principle is all the same - the Briggs write up still applies here, you'll just need to take a careful look and apply the principles to your engine.
Plus the gearing is way too high.
manco36
So all I have to do is replace the sprocket and that should fix my gearing problem?
manco36
The only one I can find locally is a 60 tooth. Do you think that will make a big difference? It's only 6 more teeth then I currently have.
Also can someone confirm that there is supposed to be a big washer on the crankshaft before I put the clutch on? Seems weird to me.
jamyers
Buffalo Gap, TX
6:1 gearing will help, but assuming you have 14" tall tires the kart is going to need to get up to just over 12mph for the clutch to lock up and match the engine's 1800RPM (the usual cent clutch engagement speed). Your top speed (at 3600RPM) would then be 25MPH, respectable for any kart.
Seriously, play around with the "Gear Ratio, MPH, Tire Diameter, and RPM" equations in the sticky. Plug different gear ratios and engine rpm in and you'll see the speeds you 'should' be doing (assuming all else is ok).
As far as the washer/clutch issue, the only reason you'd need one is to align the clutch sprocket with the axle sprocket.
I would definately look for at least a 72T sprocket. you will probably just be wasting your time with a 60T. You should be able to order one online. Just make sure you get the correct pitch sprocket
manco36
Well I went with the 60 tooth and...problem solved! Thanks so much for the help everybody!! Wouldn't have known about gearing and sprocket changes if it weren't for this forum. So happy right now!!
Still cant figure out how to make that throttle near the carb go in a little further and stay. When im riding if I press that thing in further I go FLYING! Not that I want it all the way but just a little more power. Anyone who knkws about this and coukd help me out I woukd appreciate it. B&S site is not helping, unless I overlooked something.
Thanks again!!
By pushing that lever with your hand, you are momentarily overriding the governor. I don't suggest doing that.
If you wish to increase the maximum available engine RPM, you'd either net a slight gain by adjusting the governor, or a larger potential gain by removing the governor complete.
manco36
I can't figure out where to make the adjustment. That's al I want its a slight adjustment. Any idea?
I can't see what your setup is like, but could you not fiddle with the little rods that push the throttle open. Make them shorter, or bend them a bit so that they open the throttle wider with the same amount of travel from the throttle plate mounted on the back of the engine.
You could maybe drill new holes in the throttle plate and mount the little rods again so that they open the throttle wider.
I hope I am making sense.
manco36
No I haven't. I've read the "Adjusting your governer" page on their website but it looks so different from mine. Do I need to remove anything to get to it? Or is the actual arm that needs adjusting shown in the above picture? (To the left of where the throttle cable hooks).
Thanks
jamyers
Buffalo Gap, TX
Mechanical. 99% of the pneumatic govs are on 3hp lawnmower vertical-shaft engines.
Yup, to the left of the throttle spring is where your governor shaft comes out of the crankcase. Blast all that grease off and you'll find a bolt and nut going through the governor arm - this tightens the arm onto the shaft. THAT is the nut/bolt you'll loosen to adjust your governor's "Static" setting, which is the starting point.
The Briggs website is showing a vertical shaft engine, but the basic linkages / parts / operation is the same for any small engine, you just have to imagine it standing up on it's end instead of laying down.
From the Briggs website, with my comments in blue:
1. Loosen the clamp bolt on the governor crank until the governor lever moves freely on the shaft. You are going to adjust the position of the lever / arm relative to the shaft
2. Move the throttle plate linkage at the carburetor until the throttle plate is wide open.
(To find the wide-open position, first position the throttle lever against the idle speed screw or a fixed stop plate. The throttle is wide open when it is all the way in the opposite direction. Or start the engine and note which way it goes to speed up the rpm) Note the governor arm's direction of rotation at the shaft as you move the throttle plate to the wide-open position. This is important for the next step.
With the throttle plate held wide open at the carburetor, use a nut driver or wrench to turn the governor shaft as far as it will turn in the same direction that the governor arm traveled earlier.
Without letting anything move, Hold the linkage and governor crank and tighten the governor arm clamp bolt.
Move the linkage manually to make sure there is no binding.
Next, you'll want to check / adjust the "Top No-Load Speed", which means the top governed rpm with the gas pedal floored. On some engines you adjust it by moving the spring between the throttle cable and the governor arm from one hole to another, on other engines you bend the tang that the spring mounts to.
