Mechanical. 99% of the pneumatic govs are on 3hp lawnmower vertical-shaft engines.
Yup, to the left of the throttle spring is where your governor shaft comes out of the crankcase. Blast all that grease off and you'll find a bolt and nut going through the governor arm - this tightens the arm onto the shaft. THAT is the nut/bolt you'll loosen to adjust your governor's "Static" setting, which is the starting point.
The Briggs website is showing a vertical shaft engine, but the basic linkages / parts / operation is the same for any small engine, you just have to imagine it standing up on it's end instead of laying down.
From the Briggs website, with my comments in blue:
1. Loosen the clamp bolt on the governor crank until the governor lever moves freely on the shaft. You are going to adjust the position of the lever / arm relative to the shaft
2. Move the throttle plate linkage at the carburetor until the throttle plate is wide open.
(To find the wide-open position, first position the throttle lever against the idle speed screw or a fixed stop plate. The throttle is wide open when it is all the way in the opposite direction. Or start the engine and note which way it goes to speed up the rpm) Note the governor arm's direction of rotation at the shaft as you move the throttle plate to the wide-open position. This is important for the next step.
With the throttle plate held wide open at the carburetor, use a nut driver or wrench to turn the governor shaft as far as it will turn in the same direction that the governor arm traveled earlier.
Without letting anything move, Hold the linkage and governor crank and tighten the governor arm clamp bolt.
Move the linkage manually to make sure there is no binding.
Next, you'll want to check / adjust the "Top No-Load Speed", which means the top governed rpm with the gas pedal floored. On some engines you adjust it by moving the spring between the throttle cable and the governor arm from one hole to another, on other engines you bend the tang that the spring mounts to.
