brand new 212cc pred. need help
Atlanta, GA
35 pitch refers to the chain. 35 chain specifically is 35 pitch chain. A 35 pitch, 10 tooth centrifugal clutch is what you need.
crazykart
Crazy member
Swartz Creek, Michigan
Wait, we all had a brain fart here... I started it lol.
You're gonna have a really really hard time finding a 10 tooth #35 clutch for that 3/4 shaft...:oops:
You might be ok if you can find an 11 tooth, but I haven't seen one of those on ebay for $20 so ya.
Your best bet is to get a 72 tooth axle sprocket and then get a 12 tooth clutch which will give you a 6:1 ratio.
Sucks I know, but ya.
kidn1980
Well I think I found a 10tooth 35 chain clutch the guy didn't know but he did have a 10tooth what would be the difference and how much
kidn1980
I was not able to get a 10tooth and got a 12 instead....and I removed low oil sensor but left "plug" where wire comes through and just cut it
If you have a 35 pitch, small tires, and a 60 tooth axle sprocket, get you a 10 tooth #35 clutch for a 3/4" shaft, $20 on ebay.
Have fun with that...
Of the "base line" clutches for a 3/4" shaft, a #35 clutch will have 12 teeth & a #40/41 will have 10 teeth; the reason being that it's the smallest number of teeth that will fit around the shaft; if you have a 10 tooth standard clutch, chances are, it's a #40/41...
