Brake Leak
dreazoian
Los Angeles
I got a custom built go kart off craigslist and needed some work. i have fixed everything but the last thing i was going to do was bleed the brakes. i poured the brake fluid then noticed it would slowly start getting wet under the caliper and leaks from there. Im not familiar at all with brakes so i would not understand any special terminology. Im hoping this is not a big problem.
lewilundz
lewis lund
north wales
if its leaking from the caliper its either the seals around the pistons in the brake calliper, or you could just have dodgy break pipe fixings or there could be a slight crack in your break pipe one of these. after the buggy has been standing a while outside the break pipes can begin to carode and if it carodes bad the slightest movement in them will cause a crack clean the break pipe and see if it is crack if not strip the calliper and check the seals on the pistones. these are what push your pads in to slow the buggy down. if it is a break in the seals then you may have to buy a new caliper depending on the type. but your brake line hoses have small bolt in ends on them if they are cross threaded that will cause loss of brake fluid or even if there not fully tightend up
thats all i can think of if its none of that then i couldnt tell you what it is mate
dreazoian
Los Angeles
How do i open the caliper to check the seals?
lewilundz
lewis lund
north wales
if its disk brake calliper you remove it from the chasis mount normally 2 15-17mil bolts then take the calliper away from the calliper mount normally 2 allan keys hidden behind 2 small plasic caps then remove pads and you should see the pistons there. then just 2 00 shaped heads with rubber around them the rubber is the sealy.
dreazoian
Los Angeles
my uncle is a mechanic and said that if its similar to a car, then the seal should be a few "o rings".. is that true or is it some other type of rubber seal. and how do i know if it is the rubber for sure? would it be ripper or something?
lewilundz
lewis lund
north wales
Yeh they can be rubber o rings yeh it will be obvious e if its coming from there because if you wipe it all down if there is a crack or the small rubber o ring seal is worn then it will become damp very quick with brake fluid but ensure you wipe it all down dry as you can before tipping brake fluid through it all again. You will be able to tell if its the seal mate
dreazoian
Los Angeles
Took it apart and this is what i got.
fowler
Bullsbrook West Aus
Wowa
What do the brake pads look like
That piston took a fair hammering
That seal is likely bad
When it is on the piston it should have a little potrution from the groove
Do if u rub your finger over it u can feel a little bump where it is
If it is brittle, cracked, got chunks missing of is really squishy
Basically with O rings they are a one time use
For the sake of $2 it's best to swap them out
As for the bore
U must clean that bore out really good
But don't use a buffer or sand paper in there
If u must sand out some corrosion
Get some 200grit wet & dry sand paper and spray crc or penatrene on it
This will act more to polish it than sand big chucks out
U must then check for any scoring or marks in the bore
Then take some more pics
Was there 2 pistons in it or just one?
Take some more pics of the piston it's self
In detail
From the look of the pic it's rooted
How hard was it to get the piston out?
Usually u must force it out with compressed air
The reason I ask is because that prong must be a tight fit
If it fell out then that's not good
When u reassemble it don't use grease
Grease and brake fluid don't mix
Also this system is unfiltered
If u must then use a little vasolene
dreazoian
Los Angeles
Wowa
As for the bore
In detail
1. which ones are the pads?? This is all i got when i opened it.
2. Is the piston that circle thing that has some sort of nail keeping it in place in picture 3?
3.Is the bore what the piston sits in? And if the circle thing is the piston, then there was only one. And it was partially cracked so i was able to pop one side out with a small screwdriver and the other side just fell out after. so it was in 2 pieces.
4. Whats the prong? The nail-like thing that holds the piston in?
Sorry about all the questions, its my first time coming across a problem with go kart brakes and i do not know much about them. And well we all got to learn at some point :eek:
dreazoian
Los Angeles
Here are a few more pictures, lets see if theyre any help.
fowler
Bullsbrook West Aus
That circle in two peices
That's the piston
It's clearly broken
It that first pic
That's the bore
It's the walls of the cylinder
I can't see the condition
As for a prong
That's auto correct for piston
Lol
U should have had 2 squarish sorta elliptical black pads in there
They are the brake pads
They are what the piston pushes on to lock against the disc
If the piston is contacting the disc then it is likely the disc is destroyed as well
It's lucky u found the leak because the set up u have there is useless for stopping
Depending on parts available u may find u are up for a new calliper and disc
Give the whole thing a good clean and post back some pics
Also post pics of the disc
dreazoian
Los Angeles
That's the piston
It's clearly broken
It that first pic
That's the bore
As for a prong
Lol
I think you might be mistaking.. The piece broken into 2 pieces that is one of the pads, and the other one has the yellow seal around it. The first picture seems to be the piston, i managed to get it out. and there was a o ring behind the piston in picture 1 that was ripped which was causing the brake fluid to leak from the side instead of creating pressure so the piston presses the pad down.
fowler
Bullsbrook West Aus
Now I'm lost
Well if u found a disc with an o ring around it then u have the piston
Replace the Oring
Check the Bore
Replace the pads
Clean the disc of rust
She's good to go
They are some odd looking pads
I don't know where u will get parts from though?
dreazoian
Los Angeles
Now I'm lost
Replace the Oring
Check the Bore
Replace the pads
She's good to go
Okay so the o ring around the piston was ripped causing the brake fluid to slip out from the side and leak instead of the piston working properly. And that rusted looking piece with yellow seal around it was one of the break pads that was glued down for some reason and i managed to take it off, and the black one broken in half was another one of the pads. The way i see it i think i just need 2 o rings, and 2 brake pads.
:iagree: The piston is either still in or back in the bore; can I assume you removed it, replaced the O ring then refitted the piston?
dreazoian
Los Angeles
Removed the piston but it is still out. Problem is im having trouble finding the correct pads and o ring for my brakes. The model seems to be "Kelsey Hayes 400h" If you know where i can get the pads and o ring, please do let me know, it would be greatly appreciated.
dreazoian
Los Angeles
Just a few more pictures of the piston and pads.
jandj
Williamsburg, Va
First of all, do a Google search for Kelsey Hayes 400h and you'll find the o ring and pads. Second - the reason one pad looks like it had glue on it is because it did. You have a single piston caliper so the pad on the non-piston side is "captive" in the anvil (that's the other half of the housing). The glue secures the pad in the anvil. A single piston caliper in a solid mount means your disc has to "float" in order to work properly. In other words` when you apply the brakes the piston pushes the pad on it's side against the disc which slides against the pad in the anvil. The alternative method is a solid mounted disc and a mount that lets the caliper float.The caliper you have is similar in design to the Airheart calipers that showed up on racing karts in the mid 60's and is still used on vintage karts (I have one on my Rupp Superdart project).
dreazoian
Los Angeles
I've looked everywhere! Only thing i could find for the o-ring was this and i asked the seller and they said it is one o-ring. As for brake pads im having trouble finding the correct ones. Only ones i found that are similar are this
this
and this
And for the pad without the piston, what kind of glue would be best to secure it?
