Wowa
What do the brake pads look like
That piston took a fair hammering
That seal is likely bad
When it is on the piston it should have a little potrution from the groove
Do if u rub your finger over it u can feel a little bump where it is
If it is brittle, cracked, got chunks missing of is really squishy
Basically with O rings they are a one time use
For the sake of $2 it's best to swap them out
As for the bore
U must clean that bore out really good
But don't use a buffer or sand paper in there
If u must sand out some corrosion
Get some 200grit wet & dry sand paper and spray crc or penatrene on it
This will act more to polish it than sand big chucks out
U must then check for any scoring or marks in the bore
Then take some more pics
Was there 2 pistons in it or just one?
Take some more pics of the piston it's self
In detail
From the look of the pic it's rooted
How hard was it to get the piston out?
Usually u must force it out with compressed air
The reason I ask is because that prong must be a tight fit
If it fell out then that's not good
When u reassemble it don't use grease
Grease and brake fluid don't mix
Also this system is unfiltered
If u must then use a little vasolene
1. which ones are the pads?? This is all i got when i opened it.
2. Is the piston that circle thing that has some sort of nail keeping it in place in picture 3?
3.Is the bore what the piston sits in? And if the circle thing is the piston, then there was only one. And it was partially cracked so i was able to pop one side out with a small screwdriver and the other side just fell out after. so it was in 2 pieces.
4. Whats the prong? The nail-like thing that holds the piston in?
Sorry about all the questions, its my first time coming across a problem with go kart brakes and i do not know much about them. And well we all got to learn at some point
