Bugzuki
My eye's are starting to hurt trying to find that low bar your talking about! It looks excellent, at this rate you will be driving the thing soon!!
I am talking about the bar at the back of the upper control arm support bars. It is 1/4 inch low on the passengerside than on the drivers side. This causes the suspension on the passenger side to extend down at full droop than the drivers side. So the frame sits at an angle.
In this picture you can kind of tell that the passengers side is higher than the drivers side.
Thanks for the comments, but remember we started building this in November. I just did not know about this forum till last week, so I had to catch you up on the progress till now.
The wheel base is about 57" in the mockup. That might change according to the rear suspension design. The front width is currently 53" with not much weight on it. Rear is about 57 to 60" due to wider tires.
Hopefully we will be able to get some more of the bushings made tonight and some of the control arms built.
We are making everything. I am trying to get the boys to understand the need to actually cut things to the correct length, but they just don't get the need. 12 7/8th is close enough to 13 isn't it.
