bolt holding on clutch help
webstertroy90
the bolt going into my shaft holding my clutch in keeps coming un screwed.. I have a lock washer on it what should I do.
kendelrk
redneck engineer
westland michigan
then what you need to do is take out the spark plug and stick thick rope down itm then pull and itll soon lock up, then you can tighten it, or its either the wrong sort of thread of bolt, or dosent tighten down that much,
redsox985
PA
Nope, just pull the starting rope out a bit, maybe 6" or so, and then tighten it. This should keep the shaft still.
