Big Block Engine Plate on CT200U
Dallas, TX
So I acquired a CT200U that I want to put my 420cc in it... I had every intention of grinding off the old engine plate and welding in a new one for the big block and call it a day. Randomly I searched for the engine plates and I found this on NRRacing.
http://www.nrracing.com/product-p/mbplate-390.htm?CartID=1
Seems to be the same thing as what I use for the Baja engine adapter but for big blocks. Anyone use this, I am tempted to get it and just reinforce the current mount and bolt this on so in case I wanted to go back to the 196cc it as simple as bolts and done.
Just wanted to see if anyone has used this and what they think of it.
On a separate note I know the Predator fuel tank will not fit, what remote gas tank options do I have? Saw some that use a 97cc tank mounted under the seat but I have to measure clearances once the engine is mounted in there.
Thanks,
Daniel
Dallas, TX
Oh the 420 is going on there one way or another :). I may just bite the bullet and order it, $75 is a big gamble but worth it.
—Dan
KartFab
Dallas, TX
You could mount a spun aluminum tank or other external tank. Even on the back of the mini bike behind the seat looks good.
TonyMontana214
Dallas
Yes that plate works great. im using it on my trailmaster with a 390 on it. works like a charm
Sent from my SM-G965U using Tapatalk
Dallas, TX
Excellent thanks, just placed the order today!
I am still mulling ideas over for a gas tank, cannot make up my mind which look to go for :).
--Dan
