DaveGill
Rebuilding mb165 jack shaft question
This is my jack shaft..the bearing just behind the sprocket is bad..I took the nut off the shaft and took the sprocket off then hammered the shaft out of the housing..the bad bearing is pressed into,the housing I assume since I can't beat it out lol
My question is should I rebuild the jack shaft or just buy a new one? The threaded shaft was a bit chewed up as well
I'm fine with dropping 40-50$ on a new jack shaft but because I'm putting in a new engine as well can't drop the bigger money on the torque converter like I want to..
I am rebuilding it from the ground up so things are adding up fast lol
any help with the rebuild of this or direction on a new one would be great..
A site I was on had a new one but it was for the mb200 only and said it was not compatible with the 165? Not sure why
Also if you look at the pic just behind the sprocket you will see a black nub..I assume a chain tensioner? Need some direction on the as well
Than,s so much for any help
Dave
Painted black after washing degreasing and wire brushing
The brackets for the fenders are painted red also..the gas cap is staying chrome
I will start assembly in a few days so I have time to mess with jack shaft
Thanks guys
Sent from my iPad using Tapatalk
Dave
Thanks guys
