Best place to buy please jack shaft
DaveGill
saint augustine fl
Rebuilding mb165 jack shaft question
This is my jack shaft..the bearing just behind the sprocket is bad..I took the nut off the shaft and took the sprocket off then hammered the shaft out of the housing..the bad bearing is pressed into,the housing I assume since I can't beat it out lol
My question is should I rebuild the jack shaft or just buy a new one? The threaded shaft was a bit chewed up as well
I'm fine with dropping 40-50$ on a new jack shaft but because I'm putting in a new engine as well can't drop the bigger money on the torque converter like I want to..
I am rebuilding it from the ground up so things are adding up fast lol
any help with the rebuild of this or direction on a new one would be great..
A site I was on had a new one but it was for the mb200 only and said it was not compatible with the 165? Not sure why
Also if you look at the pic just behind the sprocket you will see a black nub..I assume a chain tensioner? Need some direction on the as well
Than,s so much for any help
Dave
Painted black after washing degreasing and wire brushing
The brackets for the fenders are painted red also..the gas cap is staying chrome
I will start assembly in a few days so I have time to mess with jack shaft
Thanks guys
Sent from my iPad using Tapatalk
DaveGill
saint augustine fl
I'm rebuilding a mb165 as a gift for my nephew
The jack shaft has bad bearings so it looks like I need a new one
Where is the best place to but it and the chains?
Sprockets are ok
Thanks
Dave
I will post build pics start to finish with details soon
well OMBwarehouse has fair prices on all of what you need.
you can swap JUST the bearings and keep the jackshaft if you want (well I don't know if the jackshaft is still reusable, but I think it should..)
The sprockets though, a good quality chain will wear out most sprockets as much as it wears itself down..
So make sure the sprockets are not just looking okay'ish but are indeed reusable.
If unsure just post some pics and let us decide ;)
DaveGill
saint augustine fl
Thank you
I would rather rebuild this jack shaft and use the money for a new motor
I can't seem to get the bad bearing out though
I assume it's pressed in?
Thanks for the help!!
I will post pics of the sprockets when home
rmm727
Brookville, PA
If you are going to buy the entire jackshaft, may I suggest you get the newer model that has a bolt on steel cover versus the snap on plastic one.
Ah.. There's no bearing inside :D just two bushings;
and maybe they're not as bad as you might think..
maybe a good clean and reoiling them will make it work again, otherwise you can find them as I said at ombwarehouse
http://www.ombwarehouse.com/MB165/HT65/
(check the diagram for the partnumbers; it'll open a pdf with all the parts)
rmm727
Brookville, PA
It says bushings but they are actually bearings. One style is 16mm ID x 35mm OD and the other is 16mm ID x ??mm OD (bigger than 35mm) I own 3 of these jackshafts in (old style) 2 use the 35mm OD bearings and 1 uses the other.
DaveGill
saint augustine fl
Yea they are bearings. I can see them the rear one is fine but the front one closest to the sprocket is smoked..I can see the bearings and feel the grind when I roll the sprocket
That front bearing must be pressed on though..I can't beat it out for the life of me
I will take detailed pics shortly
So it's looking like I'm better off just buying a newer style jack shaft ether way?
KartFab
I have the whole Jackshaft set up from the newer baja warrior and metal housing shroud. Has seem less than a month of use by a kid. I am converting the bike to a torque converter driven bike so I have no need for it.
$40 plus shipping and it's yours.
DaveGill
saint augustine fl
Deal
Where are u located?
PayPal u the money or square app
You can text or call me if better
904-483-**** Dave
St. Aug Florida
Thanks!!
Pics of old jack shaft and sprockets
m
rmm727
Brookville, PA
Are you trying to pound that bearing through the front (sprocket side) out the back? Doesn't work that way. Looks like 2 spots on the jackshaft housing are bent around the edge of the bearing so thats gonna make pressing it out more difficult. Might need to straighten that back out or die grind it.
Great, gran_pann for the rescue :thumbsup:
Wow.. bearings indeed... *shrugs* now that's a high quality manual isn't it :lolgoku:
Ah well.. chinese crap all the way :(
removing them is indeed not as easy as flipping a coin, but undoing the folds and pressing (or pulling) them out will still work, just in case you want to restore the jackplate even though you'll get a "like new" full set up from gran.
Now, the sprockets are indeed in perfect condition;
not cosmetically but still perfectly reuseable.
Not bad to have a replacement sprocket handy just in case ;)
Welcome to the forum Dave
Look in the upper left corner of his post, you will see his location; filling in your profile page will let us know where you are ;)
904-483-**** Dave
St. Aug Florida
Thanks!!
As this is a public forum (as in, anyone who visits the site can see the contents of any post), posting your private contact details is not a good idea, you'll end up with every nutjob calling you; please use the PM service to provide such details to other members...
DaveGill
saint augustine fl
I filled out my profile not sure why it's not displaying
I'm in a mobile so it doesn't display the profile info but I saw it when I looked in my pc
Yes the flange is pinched at the edge of the bearing I was trying to pound it out the other side
I'm looking forward to hearing from gran pan and getting the right one
Thanks for the info on the sprockets being in good shape
Thanks for the help and advice from all
Dave
DaveGill
saint augustine fl
That's crazy..this was my very first post that showed up the day after I posted it..I thought it didn't go through but it must have been delayed for some reason..sorry for the double post with the same question
KartFab
Pm sent.
Also, why are you wanting to buy a new engine? That engine on the kart may just need a good tank/fuel line/carb clean. The only way I would junk an engine like that would be because it had low compression or was seized and had low compression.
Also, here are a few items I would get for the bike too.
Seat:
http://www.ombwarehouse.com/165-033-Baja-OEM-Black-Seat-MB200-195A.html
Fake gas tank:
http://www.ombwarehouse.com/MB200-168-Baja-OEM-Decorative-Tank-Black.html
New non OEM grips/throttle (old ones break easily)
Cherry Japan ones have a metal housing I have put this on one mini bike and they work great:
http://m.ebay.com/itm/141490612086?nav=SEARCH
This other style works too
http://m.ebay.com/itm/181599332381?nav=SEARCH
DaveGill
saint augustine fl
I have the seat getting recovered by a guy I do a lot of work for..and the tins are ready for reinstall I sanded them and painted up nice..
As for the engine..I was going to replace it and keep,this one for my next project..my nephew lives in Texas and I am in fla so I won't be able to help him if it breaks or starts acting up..it won't be jinked just used I. The next project I find
The grips and breaks and all I tore apart and cleaned up and will be reinstalled..it is a pretty compete bike that just needed cleaned up
Thanks a ton..I am going to read the pm now
It did not get posted because of the spam filtering system we have. You posted too many links for a noob, so a moderator had to approve your post. I will merge it with the other
