Hi,
So I picked up a used hammerhead 80T for my kids. I thought the belt was too short because it was moving at idle. I picked up a Rotary 13053 belt because I saw it cross references on the following website: http://www.gokartmasters.com/hammerhead-80t-go-kart-belt/
However it still moves at idle. Here is a video of it.
https://drive.google.com/file/d/0B7KihqzlM1kTMW9yTk94YlgtYkU/view?pref=2&pli=1
As you can see, the motor needs some work. It only starts with starting fluid. I figure a new carb is needed. The exhaust is a straight pipe with booger welds. Also the right rear wheel is bent - see it wobbling. (i did take it off and the shaft appears fine when spinning.
So is the belt the wrong size? Could the previous owner done something else to it? I don't want to keep buying belts....
I am new to buggys and could use alot of advice!
Thanks
Joe
Thanks
Joe
