Baja Warrior Mini Bike
Bluethunder3320
haha yeah but its my friends, i didnt have it today all i had was my phone. yes the governor is in-tact. when i had it full throttle, i tried reaching under the tank, and it was already pulled back as far as it goes.
the TC puts a constant load on the engine so governor or not, it will still reach the same RPM.
kendelrk
redneck engineer
westland michigan
but i mean is it completley stock? no hole changing or so, just like it came factory i mean? and the TC puts that much on the engine? i would think the extra rpm would give you at least something
Bluethunder3320
i put the spring in hole 3, because otherwise it would shift way too early (didnt seem right) maybe its worn out. seems like it works good now. but nope the engine barely gets to 3500ish under the load. it has a burst of RPM at the beginning then gets lower and lower as i increase speed.
went to the field today to find out the MOWED THE WHOLE THING FLAT!! YEAH!
kendelrk
redneck engineer
westland michigan
even tho changing the hole on the governor messes with rpm, your sure its not messing with the motor? and your saying like it has instant torque and then the torque deteriorates with the speed that comes out of it?
kendelrk
redneck engineer
westland michigan
all he has on right now is a header, but to the actual bike he has bmx pegs welded for foot pegs from when he broke his. and he played with the governor spring
kendelrk
redneck engineer
westland michigan
naw i sure wish, found this series of videos when i was doing some research on baja mini bikes and saw this dude is pretty good and i liked how the exhaust came out
Clayton
Saskatchewan, Canada
Changed alot since the plans of the big *** tec flatty. Why is the tank white? Is it a real Honda tank? FYI, I am asking these questions becasue I haven't been on this site for a long time.
Bluethunder3320
ebay said "gx160/gx200 honda fuel tank" i realized the clone runs a LOT better than the tec flatty. it never has let me down. always starts up quick and i have no internal parts into the engine other than the exhaust swap, new tank, and new fuel line. its still on the original spark plug, even.
this engine probably is only making 1hp or so less than the tec.
howd you wrap the rubber band to hold the choke open?
its wrapped on the fuel shut off lever, and twisted around behind the air box around the choke lever.
