Bluethunder3320
- Messages
- 5,677
- Reaction score
- 22
so on my baja, the brake sticks on, for like a whole minute after i press the brake.
i can adjust how much the cable pulls back on the arm, but either it doesnt stick and i have no brakes, OR i have great brakes, but the wheel wont move for a long time once it is pressed.
the bikes an '06 and was bought this spring off craigslist for $275.
not sure if theres much i can do other than take it all apart and see whats up. just wondering if its a common problem.
the brake is one of those drum brakes that is internal pads... if that makes any sense.
its always been doing this since i had it.
i guess i havent been using brakes much...
this is the bike. but not with the tecumseh. i decided to put the clone back in. maybe eventually when the tecumseh is running perfect, i will put it back in.
EDIT: oh ya, and it CANNOT BE THE CABLE. because with the cable removed, and me manually pulling the lever back, it still sticks.
 Sounds like you're having a blast with it; that's the way it's supposed to be!!
 Sounds like you're having a blast with it; that's the way it's supposed to be!! Just try to keep it shiny side up; I'm in physical rehab right now, myself. Trust me; you have a great many things you would probably rather be doing than that. Keep the posts coming!!
